Discussion topic: Wall mounting
Message posted on 11 Apr 2022 03:35 PM
Wall mounting
Do you need to buy a separate wall mount bracket to wall mount the 43 inch tv? I have rang up and they say I do but then the instructions lead you to see there are 2 ways of wall mounting one with the sky bracket and one with a third party . If so what is the sky bracket?
Message posted on 11 Apr 2022 03:45 PM
Re: Wall mounting
@Gemma1984 the Glass TV comes with a table stand part of which can be configured to use as a wall mount. The instructions are on a template and spacers you need are in the packaging..You will need to source the fixings suitable for your wall of course see here
Message posted on 11 Apr 2022 03:59 PM
Re: Wall mounting
