18
This discussion topic is read only This discussion topic has been answered Discussion topic: Using Sky Q Box As A Hotspot
This message was authored by: JW.LEES
Hi, I have recently got Sky Q and my question is :- Where I have my box is quite remote from my router so I have hard wired it with an Ethernet cable and it works perfectly. The wifi signal from the box is very strong in this area now. Can I connect from my phone to this Sky signal and if so where would the password be located ?
This message was authored by: pjhaahl Answer
Re: Using Sky Q Box As A Hotspot
@JW.LEES You can only use Sky Q boxes as a hotspot if you are with Sky Broadband
Locked
@JW.LEES
Hotspot functionality is only available when Sky is the ISP and a Sky Hub is in use, in which case the password is the same as on the Hub.
Avatar for JW.LEES
Thank you for the info
This message was authored by: Andy+thingy
When the sky q box is connected via Ethernet rather than Wi-Fi the network name is not the same as the default router Wi-Fi network name and the password is not the same either. I have all my sky q boxes connected using Ethernet and I can see the network name in the network details on each box. I can also see that network being broadcast by the sky q boxes as the hotspot. But because it's not the same name as the router network name and it doesn't have the same password I can't connect my other (non-sky) devices to it. If I connect my sky q boxes using Wi-Fi to the router instead they broadcast the router network name and I can connect my other devices to it because I have the password. So the question is how to I get the password for the network when I connect my sky q boxes using Ethernet?
I am using sky q main box, 3 sky q mini boxes and sky q hub router.
This message was authored by: bob1234
@Andy+thingyWith Sky as your broadband provider if hot spots are working correctly you should be able to log in using your router log in.
Most people turn off WiFi in the Q boxes when they use Ethernet BUT to use the boxes as hot spots this needs to be left on.
@bob1234
thanks for your reply and while I can connect to the Wi-Fi network from my router that's not the network the q boxes are broadcasting the hotspot on. They are broadcasting the network name from the Ethernet connection. I.e. the name shown in the network details in settings. That's because they aren't on the Wi-Fi network from my router. And I can see the difference because in a room where the signal from my router is very weak but where I have a q box broadcasting the Ethernet network the Ethernet network Wi-Fi is very strong. But I can't connect my devices to it because I can't get or set the password.
@Andy+thingyGo into settings on the main Q box and then network advanced settings, if you can see a setting that says enable hotspots it does not think you are connected to the sky broadband.
If it is there try enabling it and see what happens. It only became available with the Q170 update.
This message was authored by: Dazzasky
@Andy+thingy
I have the same problem, I can't connect to the q box wifi hotspot either. I'm quite savvy with this sort of stuff but for the life of me I can't connect. I can see the hotspot but when I input the password it tells me it is temporarily unavailable. It's been like that for weeks.
@Dazzasky are your sky q boxes connected to your router by Wi-Fi or Ethernet? If it's by Wi-Fi and your using sky broadband then it should be straight forward. But if your sky q box is connected by Ethernet then you've got exactly the same issue that I have. I.e. the network name is different and I don't have the password.
@bob1234
i have that update but when I go into settings->status->network connection->network setup->advanced settings I only the option to manually set the IP settings
ditto via settings->setup->network->advanced settings
@Andy+thingyIn which case the box is set correctly and hotspots should just work with entering the details of your router name/password and any device should just work and automatically connect to the nearest Q device.
@bob1234
yeah that only works when the sky q boxes are connected to the router via Wi-Fi. When my sky q boxes are connected via Ethernet they are broadcasting on a different network name.
Here's why I'm certain. When my sky q boxes were connected by Ethernet I also had my mobile connected to the same Wi-Fi network using my router details. I used a Wi-Fi SweetSpots app on my phone that measures the signal strength in a room where I have a weak signal but also where I have a sky q mini box. The signal was showing as being really weak even when next to the sky q mini box.
Then I connected all my sky q boxes to my router using Wi-Fi instead of Ethernet and did the same test. This time the signal strength was really strong.
The reason the signal was strong when the sky q mini box was connected to the router by Wi-Fi is because it was broadcasting the same network and so my phone connected to that mini box. But when my sky q boxes were connected to my router by Ethernet they weren't broadcasting the router wifi network but instead a different one that my phone does not connect to.
Hi @Andy+thingy  They are connected via wifi however I don't have Sky broadband. I have Virgin.  We don't need another password because it would be the same one you use to connect to the router. I can see the hotspot via my mobile but just can't connect to it for some strange reason.
Locked
