This discussion topic is read only Discussion topic: UHD format pausing
This message was authored by: Totalwar2
UHD format pausing
UHD movies are pausing am I the only one?
Sky Glass Generation 1 and Sky Glass Generation 2 Sky Moblie SKY BRING BACK NEVER MISS.
Locked
This message was authored by: fizzdisco
Re: UHD format pausing
Pausing in what sense? Whilst downloading? During playback?
Avatar for Totalwar2
Level 7 icon
During playback movie downloaded fully
I've not had that happen. Is it on one particular movie? Maybe try deleting it fully from Recordings and re-download it to see if it's a problem with the master file at Sky's end, otherwise it could be a box problem at your end.
Level 7 icon
Happens on all uhd content pauses for less then a second but like all the way though the movie.But it's fine in HD format.
Have you done a full reboot of the box?
Level 7 icon
Yes and reset box as well.
Might be time for a new one then. The hard drive could be struggling with a bad sector or something like that.
Level 7 icon
Ok thanks for the advice.
Level 7 icon
Getting new box looks like my Sky Q box is faulty.
getting Pixelation on HD format and mini box having errors as well.
This message was authored by: Doc5907
Don't forget to take out your card 🙂
Sky Q 1TB UHD
LG TV
Sky Mobile
Locked
