Discussion topic: Technical Fault with BBC1
Message posted on 29 Oct 2021 04:55 PM
When watching BBC1 , if I try to pause or rewind, it tells me that there is a techical fault.
Also, for any recordings of a BBC1 programme, I can only watch the recording in its entirety, I can't fast forward, rewind or pause the recording, if I do, it says that there is a technical fault, and go backs to the very beginning of the recording.
Message posted on 29 Oct 2021 05:05 PM - last edited: 29 Oct 2021 05:07 PM
Re: Technical Fault with BBC1
@Losgar You also posted this here https://helpforum.sky.com/t5/Sky/Technical-Fault-with-BBC1/m-p/3815342#M124529
Not sure why you have posted in both the Sky+ & Sky Q forum?
Message posted on 29 Oct 2021 05:11 PM
The customer is a Sky Q customer so it belongs here, the other thread has been deleted.
Message posted on 29 Oct 2021 05:12 PM
@Losgar Have you tried rebooting your box ie
unplug your box from the wall for 30 seconds
then
plug it back in again
and
follow the onscreen instructions
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
