Discussion topic: Swann security dvr / Cctv; connection issues due to firewall?
This message was authored by Dodgyskyq This message was authored by: Dodgyskyq
Hi. Swann security support tell me I need to contact my broadband provider to adjust settings. Firewall??
dvr set up on ethernet. Can not access the Cctv on an iPad or iPhone via WiFi, but can with mobile data. I can access my Cctv from any network other than my own.
What do I do?..
Locked
This message was authored by Lisa-P1987 This message was authored by: Lisa-P1987
Re: Swann security dvr / Cctv; connection issues due to firewall?
Posted by a Sky employee
Did they give you the exact settings you needed to have changed in order to access your CCTV? There's many different things that can be changed which impact firewalls so we need more specific info to help.
Lisa - Sky Tech Team Expert
@Dodgyskyq
Its not a firewall issue if you can access it outside the network but not in. What address do you use when trying to view it from inside your network? It may be that you need to use the local address
I am NOT a Sky Employee
Dodgyskyq
Hi
thanks for this info👍 Will be in contact with Swann
Locked
