Discussion topic: Soundbox Optical stopped working
Message posted on 19 Feb 2021 12:29 PM
Hi Guys - 1st post go easy 🙂
I've had my sound box for a year now and initially it worked fine now issues. I had to switch to Optical to listen to Netflix etc as I was using the App on the TV not the Sky Q route. Then the Optical sound stopped working after a while and started playing for about a second before cutting out and me getting a TV Speakers Active message. No biggie I just switched to using Netflix through Sky Q and was able to keep it on HDMI.
The problem - new PS5 installed and Sky Q sound still playing through the Soundbox despite PS5 being on and connected through the Arc HMDI slot. Switch to Optical and I get a second of sound and then the TV Speakers active message again and it cuts off.
TV is a Sony Bravia KD 55 AF9.
Any help much appreciated 🙂
Message posted on 19 Feb 2021 12:46 PM
Re: Soundbox Optical stopped working
Hi @NickyPom
Welcome 🙂
I'm assuming here that you mean you have your PS5 plugged in to an HDMI port on your Sony
The fact it's plugged in to an ARC port on your TV isn't relevant as the soundbox doesn't support ARC
So if that is how you are wired up, to listen to your PS5 through your soundbox - it has to be through optical
My first thought about the optical cutting out - is that you should try a different optical cable and make sure it's clicking in firmly to both your TV and the soundbox
Do you have another to try ?
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
Message posted on 21 Feb 2021 01:59 PM
Hi and thanks for the reply -
Yes I have the PS5 connected to HDMI3 (ARC) into the Sony TV. Must be something up with the optical cable I guess I'll have to get another one.
Is there a better way of connecting the PS5 and the Sky Q to the Soundbox, I just followed the instructions I think?
Message posted on 21 Feb 2021 03:01 PM
Hi @NickyPom
You can never rule out a fault in the Soundbox but a new optical cable is a good place to start. If you can still get the Amazon basics one - they should be fine
As for connections - the rule is - any device with an HDMI output should go direct to the back of your TV. Apart from your Sky Q box which should go directly to the Soundbox (with a second cable out of the Soundbox and into the TV)
In that way you can make use of the Soundbox / Sky Q menu options using the Soundbox HDMI settings
Then of course the optical from your TV to the Soundbox using the Soundbox optical setting for the other devices such as your PS5
(Well done for finding a PS5 by the way 👏👏)
Sky Q 2TB main box
LG CX6LA from 2020
Message posted on 23 Feb 2021 05:25 PM
I swapped out the Optical cable for another and get the same, 1 second of sound fine followed by "TV speakers active"
I guess the Soundbox is faulty?
Message posted on 23 Feb 2021 05:41 PM
Hi @NickyPom
It would seem to be a problem with either the Soundbox optical input but it could of course be to do with your TV optical output
Do you have any other speaker with an optical input you can try ? If not then I think you have to try going down the route of "probable" fault with the Soundbox, contact Sky and see if they are willing to offer a warranty exchange
Sky Q 2TB main box
LG CX6LA from 2020
Message posted on 21 Nov 2021 12:25 AM
I'm having the same issue, same tv, tried multiple optical cables, but sound keeps switching back to tv speakers. Was a solution identified to allow the sky soundbox to play audio via optical? Please share if so! 🙂
Message posted on 21 Nov 2021 09:20 AM
Morning @Rich80100
When you say the sound keeps switching back to TV speakers - do you mean it does this suddenly in the middle of watching something? Or do you mean when you first turn the soundbox on ?
Whst TV do you have and what is your TV audio set to ?
Sky Q 2TB main box
LG CX6LA from 2020
Message posted on 24 Dec 2021 07:55 AM
Just wondering if this has been resolved. I have a similar issue in that sound output from TV apps through optical cable to Soundbox is fine but devices connected to TV via HDMI (e.g. Nintendo Switch) are now silent on Soundbox. This happened the other day and he also occurred with Sky Q mini a few weeks ago. No problem there as I normally use HDMI route but the optical by option also used to work and now does not either. Any ideas?
Message posted on 24 Dec 2021 09:08 AM
Hi @Imogen10
For my xbox I had to turn on HDMI pass through (on console settings), as the soundbox doesn't support HDMI ARC.
This allows TV to decode the signal from the xbox and then I have sound via optical setting.
I'm not sure if nintendo switch offers hdmi pass through.
Message posted on 24 Dec 2021 09:19 AM
Morning @Imogen10
Can you clarify how you have your switch connected to your TV and to your Soundbox?
I would expect you to have your Switch straight to your TV by HDMI, then an optical cable from your TV to the soundbox
The optical cable shouldn't be connected to your switch
Is that what you have ?
Sky Q 2TB main box
LG CX6LA from 2020
Message posted on 24 Dec 2021 10:47 AM
Yes that's right. HDMI from Switch to TV then optical from TV to Soundbox.
Message posted on 24 Dec 2021 11:27 AM
Probably worth trying to reset the Soundbox @Imogen10
Other than that - if you bought it from Sky in the last 2 years you should qualify for a refund / part refund (year 1 /year 2)
- Switch off the power to your Sky Soundbox at the wall and wait for the lights on the front panel to go off
- Press and hold down the power and volumedown buttons together. Don’t release them
- While you’re holding down the buttons, switch the power back on at the mains
- Keep holding down the power and volume down buttons for at least 10 seconds until the red light on your Sky Soundbox comes on and then changes to amber
- Release the power and volume down buttons
- After 5-10 seconds, your Sky Soundbox will make the boot-up sound and turn itself back on. The light will go green
Sky Q 2TB main box
LG CX6LA from 2020
Message posted on 24 Dec 2021 11:39 AM
Has it ages. Thank you though. I will try a reset.
Message posted on 08 Jan 2022 04:48 PM
Hi,
I'm having this exact problem, has anyone managed to fix the problem? I've tried a new optical cable but no joy. Thanks
