Discussion topic: Soundbox Languag
Message posted on 18 Mar 2021 05:21 PM
Soundbox Languag
Is it possible to change the language of the soundbox commands? Not the language of the TV or stream, but the laguage of the commands, when I press the source button on the remote control.
Message posted on 18 Mar 2021 05:53 PM - last edited: 18 Mar 2021 05:58 PM
Re: Soundbox Languag
Hi @LoMich
There is nothing in the settings that allows you to do this
It could be that when these are setup at the factory they have language options but I've never heard of anyone mentioning anything other than English
There is a USB input at the back for engineer's use but I can't imagine where you could get the software from
edit: this is the link for a firmware update - but the last update was 2018 so I personally wouldn't try it unless you are desperate to see if there is any setup option as part of the update
https://www.sky.com/help/articles/update-your-sky-soundbox
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
