This discussion topic is read only Discussion topic: Connected correctly? No sky picture...
This message was authored by: ljg007
Just recieved a soundbox that works, attached pink from soundbox to tv, pink from sky q to soundbox and no sky picture or sound (signal). We had it set up incorrectly earlier and had picture and sound so we know the box works, but wouldn't let us control the volume with the sky q remote. We are now stuck!  Can anyone please help?
Locked
This message was authored by: mike+simmonds
Re: Connected correctly? No sky picture...
Hi @ljg007
Let's try a few things
So you have a high speed HDMI cable out of your Sky Q box and IN (the black port) to your Soundbox
Then a second high speed HDMI cable OUT of your Soundbox (the pink port)  and into an HDMI port of your TV
You have them selected the correct HDMI input on your TV (1,2 or 3 etc)
You have selected HDMI on your soundbox remote (press the " little square with an arrow" button - and you have turned the volume up
On your Sky box you have selected an output resolution  your TV can cope with (so say 1080p if you don't have a UHD TV)
Let me know if all those are ok and what you see or hear
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
Avatar for ljg007
Something in that seemed to work! Thank you 😊
Good news @ljg007
Thanks for confirming 👍
Sky Q 2TB main box
LG CX6LA from 2020
Locked
