Discussion topic: Sky tv
Message posted on 06 Apr 2022 10:50 AM
Sky tv
I want to downgrade as I can't cancel my contract
Message posted on 06 Apr 2022 10:51 AM
Re: Sky tv
@Claxt wrote:I want to downgrade as I can't cancel my contract
@Claxt to do that you will have to call Sky.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Say 'technical' when prompted, stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
Sky Q 1TB UHD
LG TV
Sky Mobile
Message posted on 06 Apr 2022 10:54 AM
Re: Sky tv
@Claxt You will need to call Sky or use the following link https://www.sky.com/help/articles/cancel-sky-tv#contact-leave
On the link provided (In the UK) it should include a Message Us option between 0900-1930.
You can also call on 150 from a Sky Mobile or Sky Talk line
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
If you don't see the Contact options on the link above make sure java script is enabled on your browser.
