This discussion topic is read only Discussion topic: Sky q remote won’t control sky box
This message was authored by: Scottish172
My sky q remote on my mini box in my bedroom has stopped working, having to use a app to control everything. No buttons are stuck and batteries are ok as lighting up when I press all buttons I have tried pressing 7 + 9 but flashes 4 times then nothing else happens. All I can find online is how to pair it to the TV which I know how to do but it's not the TV I'm looking to control it's the sky box itself. Thanks
Locked
Re: Sky q remote won’t control sky box
@Scottish172 7 & 9 deletes the pairing you need 1 & 3 to pair the box by bluetooth then you have to go through the TV matching again. See https://www.sky.com/help/diagnostics/sky-q-remotes/what-would-you-like-help-with
Avatar for Scottish172
Hi
when I press 7 and 9 and then 1 and 3 nothing happens nothing comes up. I am not trying to pair the remote to my TV I'm trying to pair it to the sky box itself as nothing works at all.
This message was authored by: Rhonny
@Scottish172
If you don't pair it to the TV, you can't change the volume as the Sky Q box doesn't have built-in volume.
After holding 7 and 9 to reset the remote (flashes 4 times) you then hold 1 and 3 which should bring up instructions on screen to re-pair the remote.
@Scottish172 if the process in the link I posted doesnt work your remote is faulty. When pressing the number pairs do so at the sametime and hold the buttons down until the led blinks which takes a few seconds. You have to reprogram your TV control after pairing the remote to the Q box that is how Sky designed the system.
Locked
