Discussion topic: Sky Sport HD Poor Quality
Message posted on 06 Sep 2021 10:25 AM
Re: Sky Sport HD Poor Quality
@luke+12 wrote:Propley your tv
Que ?
Sky Q 1TB UHD
LG TV
Sky Mobile
Message posted on 06 Sep 2021 10:27 AM
Ring sky and ask them to do a signal refresh it might be the signal to the dish
Message posted on 06 Sep 2021 10:32 AM
@luke+12 , absolute tripe. Unless you can offer some sensible advice I suggest you refrain from posting.
Message posted on 06 Sep 2021 10:39 AM
I used to work for sky so I know what I'm on about
Message posted on 06 Sep 2021 10:46 AM
“I used to work for sky so I know what I'm on about“
@luke+12 , If you say so.
Message posted on 06 Sep 2021 10:49 AM
Can you put us out of our misery and confirm that those channels that come first 401, 402, 403... actually say HD in the channel names in your programme guide?
Message posted on 06 Sep 2021 09:21 PM
First photo is SKY Sports HD 401
2nd one is ITV HD 103
third one is Sky Sports HD 401
All from the SKY Q box same settings. Clearly see the ITV picture is much better. All from the World Cup Qualifiers so should be the same source for the broadcaster.
Message posted on 06 Sep 2021 09:36 PM
Ring sky and tell them then they will send someone out to look at it for you them might even change you box for you with if they do you will lose all your recordings
Message posted on 06 Sep 2021 09:41 PM
@luke+12 But it's exactly the same Satellite Signal that everyone gets, there is no "refresh" as you put it. You either get a signal or you don't there is no in between.
Message posted on 06 Sep 2021 10:07 PM
@luke+12 wrote:I used to work for sky so I know what I'm on about
As....???
