Discussion topic: Sky Q volume settings
Message posted on 11 Nov 2021 07:38 AM
Hi. My box goes into standby at night. In the morning when I switch it on it automaticaly goes to 100 volume.
Message posted on 11 Nov 2021 07:40 AM
Re: Sky Q volume settings
hi @Pablo1956 the SKy boxes have no volume controls at all - the volume is controlled by your TV (or Soundbar/ sound system)
Message posted on 11 Nov 2021 08:13 AM
So why do I have a volume control on my SKY-Q remote control? not there for a fashon accessory.
Message posted on 11 Nov 2021 08:22 AM
@Pablo1956 wrote:So why do I have a volume control on my SKY-Q remote control? not there for a fashon accessory.
As already explained to you, the volume controls on the remote control 3rd party equipment such as a a TV, Amp or sound bar.
Q only outputs digital sound and there's no concept of a master volume.
Your issue seems to be with your other equipment but being rude to other customers isn't helpful.
Message posted on 11 Nov 2021 08:23 AM - last edited: 11 Nov 2021 08:24 AM
The volume controls on your SKY remote are 'paired ' with your TV to adjust your TV volume - i.e. it is set to use the same 'codes' as your TV remote uses - just a convenient way of not needing to use separate remote controls
