Discussion topic: Sky Q remote setup for TV not working?
Message posted on 01 Sep 2021 12:48 PM
Hi all,
I recently had Sky Q installed, and had my TV delivered from storage, unfortunately the remote for it has been lost. I'm trying to set my sky remote to control the TV, I select it from the settings menu as advised, then all I get is a blue screen titled 'remote control setup', with 'please wait' underneath, and thats it. Nothing happens. What can I do to sort this?
Message posted on 01 Sep 2021 01:14 PM
@Chriscook1986 reboot the Q box by unplugging the mains for 30 seconds which should clear the glitch.
Message posted on 01 Sep 2021 12:51 PM
Re: Sky Q remote setup for TV not working?
@Chriscook1986 I don't think you can use a Sky remote to control a tv, apart from turning on/off and the volume.
Message posted on 01 Sep 2021 12:53 PM
That's all I want to do, to control volume and input source. Just my tv is booming at the moment an I can't turn it down.
Message posted on 01 Sep 2021 12:55 PM
@Chriscook1986 wrote:That's all I want to do, to control volume and input source. Just my tv is booming at the moment an I can't turn it down.
Full instructions here:
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
Message posted on 01 Sep 2021 01:02 PM
Thanks for the link, but I've already tried that, and it just says 'please wait', almost as if its searching for tvs or something, and the TV select screen never comes up. Do I need to have the TV connected to WiFi or anything?
Message posted on 01 Sep 2021 01:09 PM - last edited: 01 Sep 2021 01:10 PM
Hi @Chriscook1986have you tried going to
Settings - Setup - Remote Control - SKY Q Remote ?
BTW in the short term have you checked the rear of your TV for the volume control buttons - although I think some TVs these days don't have any, many do have them even if they are small and well hidden.
Message posted on 01 Sep 2021 01:36 PM
Thanks for that! Usual thing of turning it off then back on again 😄 sorted it, many thanks!
