Discussion topic: Sky Q remote controller
Message posted on 07 Apr 2022 04:26 PM
New Sky Q user .My remote contoller keyboard has buttons showing both numbers and letters. For the life of me I cannot see how to switch between the two. I saw one suggestion that pressing the number key twice would swith to the letter but not in my case. Keep pressing the number key and I keep getting the number repeated on the screen. Would appreciate some suggestions that work.
Message posted on 07 Apr 2022 04:30 PM - last edited: 07 Apr 2022 04:42 PM
Hi @Moky
You need to be in a menu that accepts letters before you can use the Alpha keys.
Such as manual search where you can scroll through the left hand characters using the Alpha keys.
Off hand I cannot think of any other place in Q where you can input Alpha characters.
Edit
There is another area where you could use the Alpha characters and that is when entering a WiFi password for 3rd Party Broadband
Hi @Moky
Edit
