The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
20 Aug 2020 12:14 PM
did this ever get resolved as I am also having the same problem?
20 Aug 2020 02:10 PM
no resolution unfortunately
20 Aug 2020 03:07 PM
we got through to Sky on the phone - they think it was our bandwith and have adjusted - and are sedning us a booster - i'll let you know if it helps.
20 Aug 2020 03:23 PM
Hi Jude,
I can't tell you if its bandwidth or not but it is a fault! after blaming BT for a long time it was them that eventually solved the problem for me. I was having another internet connection put in and while on the phone to the guy at BT he said that the problem could be the IP address. Apparently your internet IP address is constantly changing, he arranged for me to have a fixed IP address and since then my Sky Q has not dropped off. I'm not 100% its fixed for ever but so far so good.
My Last comment would relate to Sky! they were as good as a chocolate teapot. Using Covid as an excuse to cover up your poor customer service is just pathetic but to be expected.
RB
20 Aug 2020 03:50 PM
Thank you RB, At least i know what to do next if it doesnt work.
13 Oct 2020 07:18 PM
I'm having similar issue. My mini box drops connection a dozen times a day. Broadband and WiFi working fine as we have other devices connected. The mini box stops working and the network connection is still ticked in the status....and then five minutes later the status updates to a cross.
14 Oct 2020 08:52 AM
We ended up getting an engineer out and it was fixed on the spot. Get an engineer.
14 Oct 2020 09:08 AM
Hi problem needs solving urgently by Sky.
I too have had a gut full of this. I've praised sky for their service and products for years but now it seems they don't wont to resolve the issue or not at least speak out about it.
For weeks I've had mini box connectivity issues. Several people in my Postcode area started a facebook community group to see if others were having the same problem.
1) Is it the router
2) is it the Sky Q box
3) is it the mini's
4) is it the connection
5) is it wifi speed
6) is it DCHP
7) is it IP address allocation
😎 is it firmware Q12 - Q13?????
the list goes on, there are so many people with this issue.
All I know is that I've had all 3 mini's, V2 SkyQ box and SR203 router replaced TWICE - yes twice. Doesn't this ring alarm bells with Sky or the engineers. Do the engineers really care, some certainly seem to but why are they not being updated about the problem being widespread, fixed, in progress etc?
I have dithed the SR203 as it certainly has weak Wifi capabilities, thats a fact. hundreds of people will tell you some not all 3rd party ADSL routers trump sky's router.
My SR203 will pump out my speed indoors on average at 57 to 60Mb. The line in comes in at 66Mb. So I would be happy with that. My SR203 / Sky Q box / 3 mini's are all within 15 feet radius. However if I go upstairs that wifi signal drops to 10Mb or so.
So if I hook up my Asus AC68U, same location upstairs provides 50 to 60mb
So many reboots, so many unplugging. Disconnecting all my devices, moving items about, plugging in boosters, two sky engineers, the list goes on, but I cannot stabilise my connection for the mini boxes.
I can watch netflix or iplayer on all of the TV's and use the TV's apps to play these programs in all rooms flawlessly, yet I try and watch a program through the mini box it drops the connectivity or freezes randomly.
So, where does this leave us, as paying consumers we should be listened to and then advised, or offer solid advice as to what the situation is.
Lets get sky moving on this matter!!!!
Can someone confirm as at today the latest firmware
all my devices show Q120.002.13.00L
14 Oct 2020 09:43 AM
1) Is it the router
3) is it the mini's
5) is it wifi speed
6) is it DCHP
Hi @Pottersapp I can confirm that firmware Q130.000.27.04 (56vq9w0) is being rolled out starting from last Thursday!
At the present time you will not be able to manually download the update, it will auto update your box in due course!
14 Oct 2020 09:47 AM
Thanks for this info.
Do we know how long it takes Sky to completely roll out to customers?
When you check your firmware and it states 'download successful' your device will update when it goes into standby. Does this happen instantly or is this an overnight standy update?
14 Oct 2020 09:56 AM
@Pottersapp the roll out can take up to four weeks, and will auto update your box in the early hours!
15 Oct 2020 04:17 PM
I've just resorted to conencting my Q Box to my Router to overcome the constant dropouts with the mini box connection problems.
Q Box to Router hard wire - Turned off 2.4 and 5 Ghz on Q box
Connected mini to Router via wifi as not possible to cable it
Can anyway explain why the Q Box continues to turn both 2.4 and 5 Ghz wifi back on, on my Q box without any input from myself.
I'm trying to stop the Q box from communicating to the hub via wifi as I'm convinced this is the issue with mini boxes.
Its become such an issue with mulpiple engineer visits that the TAPS team are supposed to be investigating the many issues people are facing with the mini connectivity problems.
I would as a last resort use CAT cable to conenct Q box and Hub but not the 3 mini boxes. It defeats the object of wireless TV in other rooms.
Lee
15 Oct 2020 04:28 PM
Lee
Hi @Pottersapp The Mini boxes connect to the main SKYQ box via their own wifi mesh, and not through your broadband router.
Try rebooting the main SKYQ box by turning the power off at the socket for 30 sec then turn on to reboot, then do the same with your mini boxes, wait for them to fully reboot.
If you are still having connection problems with the mini boxes to your main SKYQ box then you may need a SKYQ
booster situated between your Main SKYQ box and mini boxes, the booster is provided free from SKY and will usually need an engineer visit to install!
15 Oct 2020 04:48 PM
I got in touch with sky. The issue is with their boxes being rubbish. Only wqy to get a fix is to but the booster for them. It works. But its another cost that you shouldnt have to make. I had the issue over 12 months
15 Oct 2020 04:58 PM
There is no need for a booster in my situation. Its been exhausted. I have one and makes no difference.
I now use 3rd party router which gives me WiFi through my home at 60mb both upstairs and downstairs.
It doesn't matter whether I use skys Szr203 Hub with booster or 3rd party router. Minis keep dropping out.
