Discussion topic: Sky Q Remote Compatibility
Message posted on 07 May 2021 04:53 PM
Does anyone know of an inexpensive DAC that will enable me to connect either my Sky Q box, or my new Samsung TV (which doesn't have a headphone output, only digital audio, unlike my old TV) to my preferred stereo active speaker system that will also work with the volume controls on the Sky Q remote like some sound bars?
Thanks in anticipation
Rob
Message posted on 07 May 2021 04:59 PM
Re: Sky Q Remote Compatibility
Many cheap DACs come with their own IR remote: I'd suggest the challenge you face is to find one which has a matching Q remote 'code', as that seems fairly unlikely.
Message posted on 07 May 2021 06:13 PM
That was exactly my thoughts, but I was hoping someone had already done the donkey work and found one that works as I describe!
