Discussion topic: How do I access itv on sky q main box
Message posted on 31 Jan 2020 02:01 PM
Have two new sky Q boxes but don't know how to get into extra channels so I can watch ITV
Message posted on 31 Jan 2020 02:08 PM - last edited: 31 Jan 2020 02:12 PM
Re: How do I access itv on sky q main box
Hi @Chaliljess
Welcome to Q forum
Local channel regions depend on your Postcode and cannot be changed.
You can manually add extra channels.
Message posted on 31 Jan 2020 02:13 PM - last edited: 31 Jan 2020 02:13 PM
There's an option in 'Settings' for 'Manual Tuning' where individual transmission details can be input, and that's also where they are selected to view: entries there won't populate the EPG.
@Chaliljess wrote:Have two new sky Q boxes but don't know how to get into extra channels so I can watch ITV
Hi @Chaliljess Note 2. should read "Home" not "TV Guide" https://ekayi.com/sky-channel-codes-all-you-need/
Message posted on 04 Apr 2020 03:27 PM
Can I get itv on my sky q box
Message posted on 04 Apr 2020 03:57 PM
@Anonymous
As stated above, if you are not in a region where ITV is listed in the EPG then it can be added and accessed through the manual tuning process, but this is deliberately non-user-friendly as it's effectively a way of getting around broadcasting regulations to receive services which shouldn't really be there.
Message posted on 04 Apr 2020 05:50 PM
These ITV regional channels are there and should be there but unlike BBC regions because of advertising are not on the epg.
Message posted on 04 Apr 2020 06:11 PM
I believe ITV isn't available via EPGs in Eire, which is typically why people request such information here.
Message posted on 04 Apr 2020 06:18 PM
Deleted.
Message posted on 16 Jul 2020 12:11 PM
When I get as far as "Manual Tuning" on my Samsung TV
I'm not given an option to add a channel. I'm trying to get ITV 1 and 2.
Message posted on 16 Jul 2020 12:23 PM
You need to be using the Q remote and the Settings menu on the Q box, not anything on the television.
Settings - Manual tuning - Add a channel - input channel specific fields - Find channel - Save channels
To view the channel(s) added you have to go back to Settings - Manual Tuning: they won't appear in the EPG
Message posted on 29 Dec 2020 03:30 PM
I want to get itv4 on my sky Q box. How do i do it
Message posted on 29 Dec 2020 03:44 PM
@Bowlingstrikers assuming you are in the UK it is Ch120 HD and 818 SD
Message posted on 07 Mar 2021 12:04 PM
How do I access UTV on Skyq
Message posted on 07 May 2021 02:19 PM
It seems that UTV on SkyQ in Ireland is now gone though ITV is still available.
