Discussion topic: Sky HDR
Message posted on 29 Oct 2020 10:53 PM - last edited: 29 Oct 2020 10:54 PM
Re: Sky HDR
"What are peoples experiences like with regard to handing over old hdmi & mains cables. Does the courier insist on them?"
Not sure the courier actually cares or even Sky come to that for something that's worth 50p!
All I did rather than messing about unplugging the ones I was using, I just left the new ones in the box and returned those instead.
Message posted on 30 Oct 2020 01:33 PM
Re: Sky HDR
Ordered mine via sky q box 6pm thurs 29th delivered fri 1pm 30th via dpd, driver gave me new box and took old box cables and remote away.
Message posted on 31 Oct 2020 01:56 AM
Re: Sky HDR
We had been given a date but no time slot so we got woken by courier at 08:30.
Mad rush to extract old box but all leads difficult to remove from Samsung One
Connect so left them in place and courier was OK to just take box.
Now setup uses old leads and new remote, works fine. I've kept old remote
and new leads in case Sky ask for them.
Message posted on 31 Oct 2020 08:08 AM
Re: Sky HDR
When I go to my account on my sky q box. I'm only getting the option to upgrade for £99 for either 1tb or 2tb. Is anyone else getting this? I thought it was £50. Thanks
Message posted on 31 Oct 2020 08:26 AM
Re: Sky HDR
Those of you who have had a box swap, did the new box come with a Bluetooth remote?
I swapped over yesterday and as per instructions handed over box and remote (Bluetooth touch). Replacement box (v3) only came with a non Bluetooth remote! Is this standard/normal practice?
Message posted on 31 Oct 2020 08:28 AM
Re: Sky HDR
@nkelly0 same thing happened to me dont worry £49 is deducted before it reaches your account ,
Message posted on 31 Oct 2020 08:35 AM
Re: Sky HDR
@MATT-LOUGH wrote:Those of you who have had a box swap, did the new box come with a Bluetooth remote?
At the risk of sounding condesending, are you aware that Sky don't do remotes with the touch pad anymore.
If it has a blue voice control button in the middle, that's the latest bluetooth remote.
Sky Q 2TB (V3). 2 x Mini. LG G3 65inch. LG S95 QR 9.1.5 Soundbar. Sky Full Fibre Gigafast Broadband.
Message posted on 31 Oct 2020 08:47 AM
Re: Sky HDR
Not at all! Wasn't aware. It's actually only a backup remote as I use a Logitech Elite.
Reason for asking is that it only seems to work with line of sight not Bluetooth?
Message posted on 31 Oct 2020 08:49 AM
Re: Sky HDR
@MATT-LOUGH wrote:Not at all! Wasn't aware. It's actually only a backup remote as I use a Logitech Elite.
you can only have 1 remote paired via bluetooth at a time i'm afraid.
Message posted on 31 Oct 2020 06:09 PM
Re: Sky HDR
What a difference my new sky q box over my original v1 box,watching the liverpool game in uhd and the quality is so much better, my old one looked like it was HD when saying uhd, I wonder if the boxes degrade over time
Message posted on 01 Nov 2020 10:56 AM - last edited: 01 Nov 2020 10:57 AM
Re: Sky HDR
hi, whats the procedure for upgrading now? i'm got the non-HDR Sky Q box, registered my interest months ago on www.sky.com/hdr but was never contacted.
Alistair
Message posted on 01 Nov 2020 01:49 PM
Re: Sky HDR
Just order one via Your Account on your Sky Q box.
Message posted on 01 Nov 2020 09:12 PM - last edited: 01 Nov 2020 09:13 PM
Re: Sky HDR
hi @Rhonny,. i am still getting this message when i go onto my Account, HDR section, on my Sky Q box. i called my Sky and begrudgingly paid the £50 for the box swap. what do i need to put in box when i send my old Sky Q box away, cable, both remotes etc ?
Alistair
Message posted on 02 Nov 2020 06:19 AM
Re: Sky HDR
You should follow the instructions in your email. I wouldn't disconnect any cables other than to remove your box, and I don't believe the remote controls have to go back. It won't cripple the business of you keep them.
Message posted on 02 Nov 2020 07:54 PM
Re: Sky HDR
I'm in ireland so had to sent the box back myself after getting the new one, haven't yet. Been 2 months and I doubt they will ask for it.
