36
Discussion topic: Sky +HD remote code for a Hitachi 43hb26t72u
Locked
This message was authored by TallPaul1969 This message was authored by: TallPaul1969
Re: Sky +HD remote code for a Hitachi 43hb26t72u
Hey this is the second time I have written this as my phone died as I finished writing it .
just press tv and release , then hold select and red button until double flash.
press tv snd release and then press power and release , keep doing those last 2 things until tv turns off , then push select and release button . Done
This message was authored by Mark39 This message was authored by: Mark39
Thanks @TallPaul1969, this procedure was posted earlier in the thread. I don't believe anybody has found a code that works,  though.
Hi
yes I couldn't find a code but this way goes through the codes without having to put a code in and keep going until it finds one , it's the only way and worked for me .
thanks
Paul
@TallPaul1969 wrote:
Hi
Good that you found a code - for the benefit of others who are struggling to find a code for this tv, can you share it here?
This message was authored by willow2 This message was authored by: willow2
I have just managed to get my remote to work on my Hitachi by using a Sharp code, I think Toshiba might work as well
This message was authored by Marcollo This message was authored by: Marcollo
Im having same problem oddly the mute works but just cant get volume to work , so frustrating
Same here
Locked
