The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
16 Jun 2020 12:29 PM
I had to move my TV (house decoration). Afterwards I switched on my TV (and Sky). Initially I couldn't get a synopsis of the TV programme. I thought I'd fixed it by changing the input 2 signal to 'OFF' . Now I can't get the synpopsis or record a programme whilst watching another. The TV also now defaults to a programme I had recorded. Help!!
16 Jun 2020 01:31 PM
Posted by a Superuser, not a Sky employee. Find out moreDid you also disconnect your Sky box? If so, I suspect you've inadvertently disturbed one of the dish cable connectors. Turn your Sky box off at the plug, and unplug both dish cables from your Sky box. Look through the open ends of the plugs and in the centre you should see a pin. Make sure the pin in each plug is straight. If one of them is bent to the side, use a screwdriver or something similar to carefully bend it straight again. Then reconnect, ,making sure you line up the plug and socket accurately when you push it in and restart your Sky box.
Turn off Single Feed Mode, if you turned it on and check for two good signals.
If tjay doesn't resolve it, your best option is to call Sky and report the fault.
16 Jun 2020 01:47 PM
Thank you for responding Mark. I have tried to check this out in the sky community beforehand. Just tried your suggestion. I think I need to call an engineer!!
12 May 2021 10:31 PM
I've a similar problem, though Input 2 failed out of the blue, we hadn't moved or disturbed the cables.
I've checked the connections and also swapped the cables over between the inputs. All I then got was no signal on BOTH Inputs. I would have thought it was a cable issue it would move the problem to Input 1.
Could the fault be internal to the box?
12 May 2021 11:07 PM
Posted by a Superuser, not a Sky employee. Find out moreit could be the Sky box and/or the cables and/or the LNB on the dish
13 May 2021 08:44 AM
Thanks.
We've got a second box that is fine so that hopefully rules out the dish. But am I right in assuming it will have its own cables?
13 May 2021 08:58 AM
You mean your second box will have its own cables? That's unlikely as dish cables aren't provided with Sky boxes.
