6
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky +HD going back 24hrs within the guide
This message was authored by: RosieFace
Hi there,
We have recently got our Sky+ installed and noticed there was a -24hrs button with the guide but whenever this is pressed we get a message stating there is no information available? Is there another way to view the programme that were previously on?
Many Thanks
Re: Sky +HD going back 24hrs within the guide
That button doesn't work like that as it will only work if you have selected a channel, for example BBC 1 and pressed the yellow button to go forward 24 hours, then you can press the blue button to go back to the programs that are on right now. You can not go back in time with the Sky+ box.
Locked
Avatar for RosieFace
Hi @caesarome,
Thank you for your reply! I see, is this a feature with Sky Q?
Many Thanks
The Sky Q TV guide works like the Sky+ one, you cannot time travel to the past
No, it works in the same way with Sky Q. You can't go back 24 hours from now, via the TV Guide.
Hi @Annie+UK,
Ahhh I see! Thank you very much for your reply!
Many Thanks
Thank you both!
Many Thanks
Locked
