726
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Glass/Stream Homepage Problems
Locked
This message was authored by: Donc22
Re: Sorry there are no programmes of this type available
I have Sky Stream and I'm getting the same error message when I switched it on. I restarted the puck and it's still the same.
This message was authored by: stupotty65
Re: Sky glass menu not working
@scooter1703
We are in the same boat as you and if the very same mind.
We were expecting so much more from a sky glass and we have been left sorely disappointed with issue after issue.  Includes having to reset the TV,  Puck and broadband router at regular intervals. Having to re-link
the router to TV seems to be a daily chore now.  Despite complaining to Sky CS numerous times, we are told that the equipment isn't faulty or outdated (had the same router box for 7 years!), but that the issue could be due to the "line of sight" lacking between the TV/Puck & router or the fact that there are "too many walls & floors" between the above! The solution was a signal booster, which improved things, but only slightly!
The Glass TV itself is rubbish! It was hyped up to be all singing and dancing with Dolby Atmos soundbar and ultra HD playback. In reality, it's a piece of junk!
Our LG TV with soundbar far outperforms the Glass each and every time!
Re: Sky glass tv!!!
@Leonie1616
Many posts on this fault. Use your voice remote & say tv guide, works that way until Sky fix it apparently.
This message was authored by: Templar18
Thank god its not just me!
I guess this is an update that's broken something?
This message was authored by: PT10000
IRe: The Home Screen on Sky Glass isn’t working
I have the same issue No Home Screen, has there been an update that not working
This message was authored by: Christina6543
Sky glass not working#%*
My sky glass is not showing the home screen only saying sorry no programmes of this type available. Bit if u search will play via an app ie bbc iplayer so obviously the TV and not the broadband. I have done the usually restarts any ideas?
This message was authored by: mummymick
Sky glass
Hi I'm having trouble with my sky glass can't get it of sky cinema only be voice button can anyone help ?
This message was authored by: steveuk71
Re: I turn on my tv sky glass and it just keep saying sorry there currently no programmes of this ty
Has sky not recognised this issue yet and updated the service page so that everyone is not restarting TV and routers!!!!
This message was authored by: Davy+Howie
You can use the mic on your remote as a work around until it's fixed , just ask for the tv guide or app you want .
This message was authored by: andyq1234
Re: Sky stream stuck on A-Z of sky cinema
Thanks for this! I thought I was going mad!
This message was authored by: Bev7
My sky glass is stuck on sky cinema, can't get anything else on.
Solved, it changed with the voice control
This message was authored by: EpiphanyEve
Same issue here!
This message was authored by: TheStraightener
Re: Sky glass tv!!!
Haha I'm so glad you said about the voice  command otherwise I'd be staring at a blue screen all day. Thank you.
This message was authored by: Suvs
Re: No programs available
I couldn't see any recent posts about this fault & didn't realise I could use the voice search, that's great, thanks 👍🏼
This message was authored by: Skymatty
I have the same error message. Tried switching off and on and unplugging. No luck. Internet is working fine.
Locked
Answered - Go to Answer
