726
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Glass/Stream Homepage Problems
Locked
Re: My sky glass says, sorry, there are currently no programmes of this type available.
@Paddywackwack system wide fault. Voice control works while Sky fix it.
This message was authored by: Quartem
Re: Has anybody else got a problem with sky glass being stuck on sky cinema? Both main tv and puck
Same issue. Stuck on SKY cinema. Can move off using voice controls but home button takes me back to same problem. SKY Glass TV and all pucks have the same issue
This message was authored by: Jami3UK
Re: Sky remote Home button not working.
Good morning @Kingy2kingy ,
There seems to be a widespread outage to Sky's TV service. If you hold the microphone button down on your remote and ask for the guide (or whatever you need) then that should bring up what you need and you can go from there. It's a temporary fix until sky sort themselves out.
Cheers,
Jamie
This message was authored by: holyground
Re: Sky glass menu not working
looks like we are all havinf the same problem
This message was authored by: LChenery
Re: I turn on my tv sky glass and it just keep saying sorry there currently no programmes of this ty
Hi, if you press mic button and ask for a channel of your choice it gets round the streaming issue. Hope that works for you.
Re: My sky puck is not working and is coming on with a screen message.
@Helz1994
Many posts on this fault. Use your voice remote & say tv guide, works that way until Sky fix it apparently.
This message was authored by: Installer1
Same issue, stuck on a-z cinema, But... "Hello Sky Listings" or just "Listings" in to mic on remote gets more options for you to select from. Not a fix but better than nothing
Sky Glass and puk
Been a customer for 30 years
This message was authored by: Sophia+HS
I have exact same issue
This message was authored by: Mossbird29
Sky might be blissfully unaware how much their service is FUBARed if the app is anything to go by.
7DFD80B3-8C28-4836-A05B-5161969D1451.jpegHas anyone got through on the phone yet?
This message was authored by: Mangolot
Morning all. I have the same issue with my Sky Glass Homepage not working. At least I'm not alone! Would be good if we had a way to manually rollback to the previous version. Hope the support team at Sky fix it soon!
This message was authored by: Hello+CARLA
My sky glass and puck are saying sorry there are no channels available. Turned all devices on and off and still no joy.
This message was authored by: Declan160398
Re: Only getting A-Z sky cinema on sky glass
I've got the same issue with our sky glass and sky puck. Never had this issue before
This message was authored by: Rorymac2021
Sky streaming not working. Constantly buffering with message: "Currently no programmes of this type
Not streaming. On screen message: "....currently no programmes of this type available."
This message was authored by: Saz76
Re: The Home Screen on Sky Glass isn’t working
Sky glass Home Screen not working. Locked on sky cinema. Only able to use voice control. What is going on!!! Would recommend sky glass, loads of issues over the last 4 months and only had it for 4 months.
This message was authored by: Hantsxlg
Re: Sky stream stuck on A-Z of sky cinema
Mine to! Sky I think you have broken all the pucks!! P1 issue please
Locked
Answered - Go to Answer
