Discussion topic: Sky Glass/Stream Homepage Problems
Message posted on 03 Feb 2023 07:01 AM
Re: Only getting A-Z sky cinema on sky glass
I've got the same issue this morning, and it's not the first time this happened.
Let's hope someone from sky can sort this one out!
Re: The Home Screen on Sky Glass isn’t working
Sky are apparently rolling out a update to the new entertainment OS 1.1, apparently due to complete by tomorrow. Id suspect thats likely caused the problem.....
Absolute same here! Not worth the money they are charging at all!
Message posted on 03 Feb 2023 07:02 AM
Re: Sky glass screen stuck on sky cinema, won’t load from remote
Same problem here, we've got a very limited selection at the minute!! Lol
hopefully sky fix it soon
Mine is also stuck on sky movies, which is extremely annoying!
Happening with both pucks all I can do is search for programs no tv guide or anything
Message posted on 03 Feb 2023 07:03 AM
Re: I turn on my tv sky glass and it just keep saying sorry there currently no programmes of this ty
Mine seems to be the same. If you press the mic button on the remote and say 'Sky Guide' it lets you in. It's when you press the home button that the issue happens again.
Re: Sky glass menu not working
same here only works with voice control any one any ideas to fix this come sky help
Mine still not working 😭 been the same since 5am. Have to search everything with voice on the remote. I have A-Z of cinema and nothing else!! Reset the whole tv!!
Also same problem here in Kent, not sure if it's a firmware upgrade gone wrong or a problem with the backend servers but it would be nice if they tested updates before applying them or have someone on call when they see there is a problem with the platform which is after all a 24 hour 365 system. Not expecting 24 hour customer support but there should backend server support. Hopefully they sort it soon!
My remote has stopped working at the same time, is there any other way to to this?
Message posted on 03 Feb 2023 07:04 AM
Re: Sky glass
Same problem reported up and down the country.
Try using the voice control to go to a channel.
Not ideal, but at least you can watch something.
I can use voice command and then can change channels with the up and down button.
pressing Home sends it back to Sky Cinema though
Message posted on 03 Feb 2023 07:05 AM
Same here cinema a-z only. Failed update?
Re: Sky Glass
