726
Discussion topic: Sky Glass/Stream Homepage Problems
Locked
This message was authored by Rh2503 This message was authored by: Rh2503
Re: Sky Stream message
Thanks hopefully they fix it quick but at least I can put the tv on for the kids
This message was authored by DCARTER-UK This message was authored by: DCARTER-UK
Re: Can’t load sky glass
Same issue here this morning on my sky glass TV and 2 streaming boxes.
I found out voice controls work though as a workaround, however no main menu!
This message was authored by Davy+Howie This message was authored by: Davy+Howie
Re: I turn on my tv sky glass and it just keep saying sorry there currently no programmes of this ty
Thanx , that worked 👍🏼👍🏼
This message was authored by Damian7373 This message was authored by: Damian7373
Re: The Home Screen on Sky Glass isn’t working
This message was authored by Jimmybest This message was authored by: Jimmybest
Stuck on sky cinema re booted several times no change voice control no joy either
This message was authored by Sam2.3 This message was authored by: Sam2.3
Must be a world wide sky glass issue by the sounds of it
This message was authored by D0dferatu This message was authored by: D0dferatu
Same problem reported up and down the country.
Try using the voice control to go to a channel.
Not ideal, but at least you can watch something.
I wish Sky would reply to one of these posts instead of locking and moving them.
This message was authored by i8forest This message was authored by: i8forest
Re: Only getting A-Z sky cinema on sky glass
Same issue for me - Home button only shows me Sky Cinema .
Tried the usual power off and leave cycle but still not working.
Lools like a major issue with Sky Glass for all users - this is terrible I wish I had never had this. I went 65" and have never had so many glitches and issues.
This message was authored by RichieR84 This message was authored by: RichieR84
Make sure your voice control switched on on side of tv
This message was authored by Pete132 This message was authored by: Pete132
Same problem, if Sky are listening is there anyway from this screen to access TV inputs (Hdmi or Aerial port)? Cannot get into main menus to access option to select.
Good news just came on but would still like answer/fix
This message was authored by AMill1975 This message was authored by: AMill1975
Re: Sky glass screen stuck on sky cinema, won’t load from remote
Glad it's not just me. I have seen similar happened back in September where sky glass was stuck on Eddie Murphy films...... grateful for small mercy's it cinema its stuck on!
This message was authored by Byebyebaby This message was authored by: Byebyebaby
When I turn on my sky glass all I get is the blue screen and saying no information available home button doesn't even do anything have to use the microphone button to get onto the TV guide what's happening
This message was authored by Jamie+Free This message was authored by: Jamie+Free
Sky Glass
Yes im getting the same...ever since ive had sky glass ive had problems..i tell everyone i know who hasn't got it never to get it
This message was authored by scott117 This message was authored by: scott117
Re: Sky stream stuck on A-Z of sky cinema
If you use the talk button and say 'what's on now?' It takes you to the normal menu
This message was authored by klou781 This message was authored by: klou781
Same here - just glad that it isn't a broken TV!
Locked
