This discussion topic is read only Discussion topic: Shopping Channels
This message was authored by: graham121
Shopping Channels
My wife is addicted to the craft shopping channels, any ideas why they are not available and if there are any plans to introduce them? I'm getting a ton of grief over this😪
Locked
Re: Shopping Channels
No one knows at present, I'm sure they will at some point, on the plus side it could save a few quid 🙂
@graham121
Presumably they aren't prepared to meet whatever additional terms Sky require for participating in Glass, or they are planning their own alternative method of online distribution.
This message was authored by: Scottishplantdad
I quite like the streamlined down channel list - ones I would rather weren't there anyway! 🤣
This message was authored by: AaronC88
My missus is the same though I did warn her about them not being there, she said most are available to watch via their websites.
This message was authored by: HeathHayle
@TimmyBGood there probably going to release their own "watch" apps like everyone else seems to be doing these days if they havent already 😂
= Sky+ SD boxes x4 (pace bskyb 3100) ===
@graham121 the shopping channels that are wanting to be watched have you checked their official sites to see if they already offer their own way of watching the channel might give you an indication to what might happen or what has already happened
This message was authored by: FoxsterUK
My wife has insisted that we get the shopping channels back or we have to cancel Glass and go back to Q.
As a temporary fix, I have plugged the Q box into Glass via HDMI. Most of Q is not working but the Freeview-type channels, including the shopping ones, are available. Marriage saved.
Once Sky want their Q box back we'll be stuffed and I'll either have to switch back to paid-for Q or maybe get a Freeview box of some sort, though I'm loath to do that as obviously Sky just need to provide the full set of channels on Glass that are available on Q.
@FoxsterUK It's not up to Sky to provide those channels, it's up to those channels to want to be part of Sky Glass.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Avatar for graham121
Level 3 icon
It was the Craft channels my wife wanted and they both stream on YouTube so that solved the problem. She used to record the demonstrations for future reference but that can't happen with Glass.
This message was authored by: Aaln
Omg those channels are dire.
I think they're designed for people sat at home who've had a few to drink, to get them to spend money they normally wouldn't.
This message was authored by: bob1234
@FoxsterUKThe problem is that with freeview you need a terrestrial aerial and with freesat you need the LNB in the dish changed back from the Q one to the normal one.
However channels like the "craft store" stream on line so something like the Amazon fire stick(from £29) or Roku dongles would work.
This message was authored by: tarbat
No you don't. the current Freesat box works perfectly well with the wideband LNB that Q uses.
Yep, the latest Freesat 4K boxes work with the Q wideband LNB so it wouldn't need changing
Yes I had forgot that however you have to make sure you get the 4K ones as there are loads of cheaper ones about that do not work with the Q LNBs.
Locked
