43
Discussion topic: SR203 to SR204
Locked
This message was authored by Neil+Stevens This message was authored by: Neil+Stevens
Re: SR203 to SR204
Will do
Re: SR203 to SR204
well so far I'm unimpressed....
when sat in the same room connected to 5Ghz i'm getting 480-500Mb download speeds but when you move away it's not so great
using wireless backhaul and it keeps dropping off the 5Ghz onto the 2.4Ghz and it says it weak and even being sat right next it download speed is only 60-70Mb
It feels like I need another unit for coverage. In my kitchen earlier I was getting 400+ whereas each time I try now i'm getting 60-70Mb
certainly doesn't feel like I'm getting much more for the money compared to my current wholehomewifi whoch is a shame
This message was authored by mae-3 This message was authored by: mae-3
Re: SR203 to SR204
@Neil+Stevens
What does the wireless log say about wireless signals and radar for the 5Ghz bands? And have you tried changing the control channels on 5Ghz?
Zen internet on G.fast (250Mbps down, 50Mbps up). SAT> IP (Apple 4K 2nd gen TV to LG C1 OLED UHD TV/Dolby Atmos Denon AVR, DacMagic Plus for Hi-Res audio), hosting own blog/forum (cluster), OPNsense & Zenarmor L4/L7 NGFW & DPI IDS/IPS, Asus ET12 Pro Tri-Band wifi, Linux, Gamer: Xbox Series X/i7 laptop, round-robin DNS over HTTPS, non-proprietary VoIP HD AMR-WB (G.722.2) and more... Beta tester Apple iOS/watchOS/tvOS/iPadOS/macOS.
Re: SR203 to SR204
Not checked the logs but already made sure the channels aren't conflicting
Re: SR203 to SR204
If I kept don't split the networks and just have a single ssid will each client automatically connect then swap between 2.4 and 5 when it needs to?
Re: SR203 to SR204
@Neil+Stevens
It should do but most split the SSID's for assurance that it connects always to the required wireless band as necessary manually.
Re: SR203 to SR204
Ah yes of course
Re: SR203 to SR204
Decided to start over today so did a factory reset and this seems to have done the trick. I've set it up in ap mode but as I only have the sky q mini devices that log into the sky ssid I might try it in router/aimesh router mode and see if the double Nat will cause any issues
Re: SR203 to SR204
@Neil+Stevens
The xt8 is capable of authenticating sky mer, client identifier option 61 so can completely replace the sr203 . All units are combined router/satellite nodes therefore with xt8 plugged directly into ont you can use the main router unit to set up aimesh
Re: SR203 to SR204
There's no solution for sky voip yet though is there ?
Re: SR203 to SR204
@Neil+Stevens
That does mean however you can't use sky internet calls
Re: SR203 to SR204
@Neil+Stevens
Disabling wifi and unticking "use router as dhcp server" on the advanced->lan ip set up should avoid double nat. Don't know whether sr203 still does the authentication vis a vis dhcp option 61 but does pass lan dhcp allocation over to the xt8. What this will do to internet calls i don't know
Re: SR203 to SR204
@Neil+Stevens & @cookiemonsteruk
If the Asus XT8's are in AP mode you can either run the Sky Hub as the DHCP server or one of the Asus XT8 as a DHCP server. When the DHCP server is turned off on the Sky router it is still doing the authentication with the Sky backend, eg: it doesn't matter what the DHCP server is set to on the Sky router it still does NAT and authentication with Sky.
The fact the Asus XT8's are in AP mode means they don't NAT the connection again and this is what avoids double NAT.
Re: SR203 to SR204
hadn't planned on getting rid of the sky hub as happy with the skyq mesh dealing with the sky q minis. When I first set up the XT8 I did notice the auto setup was in router mode with my phone and Mac that were connected were in the 192.168.50 range but I changed it to ap mode straight away. I should have tried running sky go to see if there were any issues
Locked
