5
This discussion topic is read only This discussion topic has been answered Discussion topic: SKY Q Mini confusion over how many
This message was authored by: Lstry
OK so i have the 1TB Sky Q box in my living room and a Sky Q Mini in one of my bedrooms now i am wishing to add a second Mini in another bedroom now my confusion is if i add another mini does this mean i could only watch 2 at the same time ie front room(main q Box)and bedroom(mini) or can i watch my main sky Q box and say the 2 in the bedrooms at the same time so in theory this would be 3, Q main box and 2xmini's
hope this makes sense
thank in advance
Re: SKY Q Mini confusion over how many
thank in advance
Hi @Lstry
If the 1 TB box that you have is the original non UHD one then you can only use one mini at a time.
With all other Q boxes you can use two minis simultaneously.
See the following link
See which Q box you have
Locked
thank in advance
Hi @Lstry
thank in advance
@Lstry it depends on what 1TB box you have
If you have the older non UHD 1TB box then you can only watch on your main box and 1 mini at the same time.
If you have the newer 1TB UHD box then you can watch on your main box and 2 minis at the same time
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
hi @Lstry
Further to the replies by @Laing1 & @oldfella should you need to check which box you have look in :
The original 1TB non UHD box shows as Hardware Version  32Cxxx
(edit : This info shows in the Link @oldfella added)
Avatar for Lstry
Thank you to everyone who took the time out of there day to help me with my confusion you have cleared things up for me
Have a Great day all
This message was authored by: kop32
Now THAT is how to give thanks on a Forum, wish more peple would take the time just to acknowledge help.
3 x Sky Stream (trying again) , VM 1 gb Broadband and Google Nest WiFi Pro.
Locked
