The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
23 Jul 2021 06:51 PM
Long shot, but does anyone use Unraid? And if so, do you have a reverse proxy using SWAG?
I had it all set up and working for months, changed ISP and router to this circus, and now cannot forward the ports I need using the antiquated UI.
I'm trying to open 80 and 443 and then forward that to 180 and 1443 on the local IP of my server.
See - https://youtu.be/I0lhZc25Sro?t=623
Can anyone advise how to do that?
23 Jul 2021 11:37 PM
Posted by a Superuser, not a Sky employee. Find out moreAs far as I know the Sky hub doesnt work when you try to create rules that change ports. It needs to be a 1 to 1 mapping. E.g. Port 443 > Internal port 443.
23 Jul 2021 11:54 PM
Ugh, well that sucks. Even the HH3 could do that. Thanks mate, will use my 30 day cooling off and go to plusnet!
15 Sep 2021 05:08 PM
I have the same issue.
FYI I just came from plusnet and their router isn't much better. When I was with plusnet the router kept dropping its connection in the late evening for 15 minutes or so. I soved that problem by using a third party router and modem - plusnet routers are utter trash.
It looks like your best bet is to get a nice router and use the appropriate modem for your connection. I am only using Sky's router because I don't have a G-Fast router. Unfortunatly Sky's router will not operate in modem only mode.
Sky's modem is a utter dissapointment, it is so basic as to be redundant.
16 Sep 2021 12:06 PM
Posted by a Superuser, not a Sky employee. Find out moreIts designed to be plug & play for the average technophobe, if you want advanced you get a 3rd party router like you said.
03 Nov 2021 11:55 AM
just jumping on this as I have the same issue - I need to map 443 external to 8123 internal. Reading above as I suspected the Sky box isnt going to do this. What routers do folks recommend and what are the pros and cons?
03 Nov 2021 01:21 PM
Posted by a Superuser, not a Sky employee. Find out moreRouter choice is up to yourself because there are so many things you might want/not want such as WiFi 6, gaming features, proper QoS, LAN management, child controls etc.
The requirements are that it supports DHCP option 61. You do not need to extract the login details, they are generic.
Regarding your Q boxes, you used to lose the hopspot functionality when not using a Sky router however the latest update allowed for the feature to be active without a Sky hub. That being said if you get a decent 3rd party router you shouldnt need the Q hotspots.
03 Nov 2021 02:51 PM
that's great, thanks for your reply, things have improved then! - I'll look around and see what i can find. My needs are just as described .... no gaming or parental stuff - coverage and port forwarding with ability to change the port are the most important thing.
08 Nov 2021 01:06 PM
I do think that the Sky router is much better in terms of connection stability than the Plusnet one that I had (when openreach are not digging up the road!). Also the more setting, the more support tickets, so you cannot blame ISP's too much for today's lack of technological literacy
Due to a shortage of G-fast modems in the UK I had my fingers crossed for Sky's router having a few more features.
To be fair to Sky it is not altogether unreasonable to expect people like the OP wishing to host own webserver or application server to use a third party router.
You may wish to take a look at routers that can work with openWRT or building a PFsense router. If you have an interest in unraid then you might find them interesting.
I have used openWRT on the turris omina and enjoyed it - although I believe that you can flash openWRT on to cheaper devices.
08 Nov 2021 02:14 PM
Thanks I was more jumping in over the need to port map... I am using home assistant to manage my home automation and this feature is needed to expose hassio to Alexa. Anyway I bought the TPlink vr2100 and was a doddle to set up and my port 443 is now mapped to port 8123, so I'm happy.
In setting up I did keep the old box Mac address just in case, but it's been solid. The only thing I did have to do is switch on WiFi mesh at the sky main q box now that the sky router is gone. That's made a difference in my most remote location where some home automation switches were struggling to see the wi-f (slow to respond or dropping off). Everything else that streams is hard wired. Wi-fi is only used for browsing and home automation devices. Everything seems rosy now so Thanks very much to everyone that helped...
06 Jan 2022 09:30 AM - last edited: 06 Jan 2022 09:52 AM by Federica-C
Sorry to bump up and old thread but fello Unraid user here. Pretty gutted to be fair, I have ben following numerous tutorials to get my Unraid accessable from outside of my network. No luck at all.
I tried messing with the "Services table" and then creating "Inboud Firewall Rules" on the Sky Q hub but it just fails totally.
Pretty [removed] annoying tbh, are people saying i can buy any router that has DHCP option 61 capability and it will be a plug and play solution bar recconecting all my devices? I have a main Sky Q box and also 2 Minis?
Proper nightmare, tried this with SWAG and also NGiNX (So much easier... if it wasn't for sky - https://youtu.be/h1a4u72o-64)
Really is a shame, I understand that things are plug and play for your average user but they should allow an expert or modem only mode for those that do want to tinker and we can take responsibiity then.
Any other unraid users got this working?
Moderator note: profanity.
