4
This discussion topic is read only This discussion topic has been answered Discussion topic: Replacement Sky Q box - Netlfix and Prime not working
This message was authored by: TML77
I received a replacement Sky Q box as the old one was having wifi problems.
I have the new one set up and wifi is working fine, Sky TV is working fine but the internet is not working on the tv/I cant access Netflix, YouTube or Amazon Prime.
Could you advise?
Thank you
This message was authored by: GD1 Answer
Re: Replacement Sky Q box - Netlfix and Prime not working
@TML77  If the issue is with your TV have you reset the wifi connection to pick up your new Sky Hub?
It's not a Sky issue but rather a user issue, that user needs to check their TV manual to add the new wifi details to it.
Locked
hi @TML77 when you say can't access Netflix etc. is that you are having problems when using the apps or that you can't find the apps ?
Avatar for TML77
Hi, the Apps are there but when I open them they say Connectivity issues.
Thank you
Avatar for TML77
Thank you. That was the issue!! Very happy 🙂
Locked
