Discussion topic: Remote control batteries
Message posted on 17 Apr 2021 06:02 PM
Keep getting message on the tv screen saying "your remote control batteries are running low"
changed the batteries with new Duracell ones three times and the message comes back within 24 hours.
any ideals or what's wrong or what to do apart from keep changing the batteries every day.
Message posted on 17 Apr 2021 06:04 PM
Are you sure its not a TV message directing you to change the batteries on your TV remote
Re: Remote control batteries
Hi @SimonM2003
Check that none of the buttons are sticking and thenTry completly resetting your Bluetooth remote.
Press 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice and follow onscreen instructions to re- pair.
Message posted on 17 Apr 2021 07:38 PM
Sorry I forget to mention the message does specify the Sky remote control.
Message posted on 17 Apr 2021 07:54 PM
If its draining the batteries that fast and you can't find anything physically wrong with it then you are best giving Sky a call. They'll probably agree to send you a replacement. If not you can pick one up for £20-30 from loads of places
Message posted on 18 Apr 2021 06:31 PM
Called Sky this morning and they are sending me a replacement. Thank you for your help. 👍
