Discussion topic: Recordings listing
Message posted on 11 Sep 2021 07:30 PM
Recordings listing
The recordings listing format has changed on my sky box to horizontal and it was vertical . Can I change it back to the way it was ?
Message posted on 11 Sep 2021 07:39 PM
Re: Recordings listing
@Grannysky200 wrote:The recordings listing format has changed on my sky box to horizontal and it was vertical . Can I change it back to the way it was ?
As per all the other threads on this very subject, the answer is no you cannot change it.
Message posted on 12 Sep 2021 02:16 PM
It is because you will have had the new update. If you go to Settings the System Info it will start Q170. Where as previously it will have been Q160. As @GD1 says once you get an update it can't be changed back I'm afraid.
