This discussion topic is read only Discussion topic: Q box will not turn on
This message was authored by: LynneyH
I have to reboot my sky at least 3 times a night as it either goes off or freezes
now tonight when I turn it on the blue light comes on the middle of the Q box but I cannot get a green light on the right of Q box, it is red then after about 3 minutes goes amber and stays amber
It says on the TV 'check cable connections and equipment settings'
all cables checked non are loose
can anyone help please
Locked
Re: Q box will not turn on
@LynneyH  If you follow these steps, when you get to the end click need more help https://www.sky.com/help/articles/sky-q-box-wont-turn-on-v2#get-in-touch
Avatar for LynneyH
Many thanks. The light is green now and  I can hear the tv but the phrase weak or no signal check cable connection and equipment settings is on the screen
the remote works as I did the check but I cannot change volume or channel using any of the remote buttons it's stuck on a sky channel  any other ideas please?
@LynneyH if the remote does not operate the TV it sounds like it needs reprigramming which you can do by pressing 1 & 3 together and following the onscreen instructions.
Locked
