7
This discussion topic is read only This discussion topic has been answered Discussion topic: Puck wi-fi connection issue
This message was authored by: Mrs+Jacs+Harris
Literally at end of my tether with the puck in bedroom. Glass downstairs has been great but every night the wi-fi connection fails, go through whole reset process, sometimes it works but then just loses connection again. Have carried out every trouble shooting guide, our internet speed is 79, never had this problem with Q box - help!!!
This message was authored by: Aaln Answer
Re: Puck wi-fi connection issue
Q boxes acted as a mesh network, so repeating the connection to the nearest device.
Maybe you could do with a booster or new router?
Locked
This message was authored by: bradleyestn
They are not fit for purpose. My puck needs reconnecting to my internet pretty much every day. Constant issues with it.
When you first go to use it, the handshake for Internet connection seems to be the last thing initiated, even with standby WiFi enabled.
I just give it 10 or 30 seconds and press home. Usually first time it works fine.
This message was authored by: Jayboy1990
@bradleyestn  Sky aren't going to get back to you on this forums it's just customer to customer. If you have an issue that bad with the puck you would need to speak directly to sky.
This message was authored by: simonandbern
The sky puck is a piece of junk for connectivity. I have 70mbps in my bedroom but every night I turn on the puck and it says " no WiFi connection". Utter waste of time having it, don't buy
Just means the handshake to the WiFi or the sky servers hasn't finished yet.
They are no doubt aware of the issues for Glass and pucks and still working on them for a new update.
Avatar for Mrs+Jacs+Harris
I spoke to Sky and discovered my Sky router was quite old - they sent me a new one plus a booster - this has fixed the problem! My speed was fine but the strength was poor - I put the booster on my upstairs landing and it has been perfect since.
Locked
