This discussion topic is read only Discussion topic: Puck problems
Locked
This message was authored by: Toondad
Re: Puck problems
You might want to bear in mind when I ordered it on launch day 18/10 I got the p I know free!
Was a Glass customer switched back to Sky Q with full package, and maintaining Diamond membership with over 23 years with Sky. Sky Glass is not a patch on Sky Q - I kept the Sky Glass TV and now, finally, my Q remote operates volume on the Glass TV after waiting 7 months for a pairing code!
This message was authored by: discodancers
Re: Puck problems
@AndyPMack wow that actually worked. Genius!
This message was authored by: AndyPMack
Re: Puck problems
Awesome. Glad I could help. Hopefully they sort a proper firmware and software update soon
Re: Puck problems
@Toondad @I got one free and I got another for £50
This message was authored by: Simon230571
Re: Puck problems
Good luck wiv the call back ,I've been waiting 2 days for mine regarding the complete farce of glass TV
Re: Puck problems
We'll I hope I'm not speaking too soon but my Flass TV and Puck are working fine, both stable, fantastic picture quality, just a bit frustrated that ITV HUB is streaming in SD not HD,?at this stage though this is my only gripe!
This message was authored by: Charlied47
Re: Puck problems
Hi All
I had remote issues with Glass TV and Puck.
Just hold 7 & 9 on remotes to clear them. Then 1 & 3 to re-pair. Worked perfect for me.
Any activation issues, factory reset puck and start again. Only use My Sky app for activation codes (if you need to). 👍👍
This message was authored by: loontor
Re: Puck problems
OK now when I switch on the puck shows me the Home Screen when I go to the channel it's blank screen, frustrating so far.
This message was authored by: Deedee36
Re: Puck problems
@loontor  Have you tried a complete reset??
“Trying to help improve sky glass”
Re: Puck problems
Hi just did a complete reset and it looked for a network and it's asking me to point my SlyQ remote at SlyQ box and hold 4&6 together?
Re: Puck problems
Pointing the puck remote and press 4&6 together does nothing and it's stuck on that screen.
Re: Puck problems
@loontor do you have a sky q remote? If so, use it. It really works.
Re: Puck problems
Tries that it didn't work was on Sky hold for two hours got fed up. Hung up and had a thing attached Ethernet cable connected to router and hey presto we are back online hopefully this will help anyone else stuck in the same rut.
This message was authored by: DJ17A
Re: Puck problems
Yes, 3rd day of Sky Glass, switch tv on puck light be stays off.
Then switch off at main wait 15 seconds ,restart same issue.
Re: Puck problems
Reset! Pull power lead then when plugging back in hold down the button underneath the Puck until you see flashing yellow and red light this should then fix it. My remote will still not switch puck on have to press button but remote will work when switching off.
Locked
