This discussion topic is read only Discussion topic: Puck problems
Locked
This message was authored by: dogmatic6
Re: Puck problems
@peter-marlow+1966
yeah most of us experiencing same issues.
have you tried turning off overnight power saving in the puck settings menu?
this does help with it starting up in thhe morning but doesn't resolve any of the other stability/picture issues
This message was authored by: Amanda+Knight
Re: Puck problems
I'm sick of the pucks.
10% guarantee you can watch what you want to, 90% guaranteed you can't watch what you want.
When I'm told I can't watch BBC because I need to upgrade subscription (I pay £13.32 for a tv license) I start to lose my patience!
Why can I watch Dexter new series on the glass TV but the puck tv says there are no programmes of this type???
Re: Puck problems
@Amanda+Knight
that does sound strange! Sounds like your puck is not properly registered to your account if your getting subscription messages and missing content.
everything is available on my puck same as the glass tv it's just that the puck is so unstable with blank screens and picture speedup/slowdown which is extremely annoying as happens a lot.
have you tried a factory reset of the puck and re registering with your account?
This message was authored by: Geayson
Re: Puck problems
@Amanda+KnightAs you stated the next big issue with the puck now saying you need to upgrade to watch this channel even on the basic channels, Netflix when selecting a show only getting to 24% loading and freezing
Sony Bravia 7 65”, Sony Bravia 55” - Whole Home - 4 puck - Full Package TV - Sky Broadband full fibre 500 with WiFi Max
This message was authored by: PinkLouise
Re: Puck problems
This is exactly the issue with mine. Did you get a fix?
This message was authored by: MoleUK
Re: Puck problems
If you're having problems with HDMI ARC connected soundbar dropping out, try turning off HDMI control on the Puck settings.  Seems to have solved the problem for me, though I now need to select the Puck on TV input.  A bit of a fix ... until we see a SKY FIX!?
Re: Puck problems
@PinkLouise No refreshed the apps in settings a few times and eventually worked as you can't get out of the Netflix app on the glass the way you could on the Q. Bear in mind it could log you out of other apps too
This message was authored by: peter-marlow+1966
Re: Puck problems
Hi guys for you guys like myself how when resetting your puck it asks you to use your  sky q remote do this pull power out reconect and hold button for 20 seconds then when it asks you to connect to the Internet use your password to connect went straight in and did not ask for the sky q control asked for the puck control went straight in
P c marlow
Re: Puck problems
When resetting your puck to avoid being asked to use your sky q remote when asked to connect to the Internet use your Internet password word on your hub this will then after that tell you to use your sky glass remote
P c marlow
This message was authored by: shep567
Re: Puck problems
That's interesting, with the hub password, turned my wifi off on that as I am using nova tenda mesh things and changed the password,
Though why would it use your hub password though...
Re: Puck problems
To avoid this and it asking for the sky q remote when you reset the the when it asks you to connect to the Internet use your Internet password to connect and then you will be asked to use your sky glass remote not your sky q remote I have just Don this to my puck
P c marlow
Re: Puck problems
my puck has been strangely stable for the last few hours!!  No stuttering or slowdown/fast forward of picture, no black screens or weird behaviour
I could even watch the football in UHD and it was normal.
scared to move from the sofa or switch channels now lol wonder if sky are tinkering behind the scenes
This message was authored by: hori62
Re: Puck problems
Why/ what is wrong with Netflix especially evening onwards, dare they say demand is high or an outage somewhere when my old wireless Blu-ray player is as good as gold.
This message was authored by: Marto77
Re: Puck problems
I've had issues with 2 household glass pucks. Stuck on 4 and 6. Switched it off numerous times, and plugged in the Ethernet to the router. Instant software update appeared on the screen and all is good.
Avatar for Hicksy99
Level 4 icon
This message was authored by: Hicksy99
Re: Puck problems
Had to yet again reset. Now Prime video app is missing. Can't make this crap up
Locked
