This discussion topic is read only Discussion topic: Puck TV won’t turn on
This message was authored by: PHILLC01
Puck is on
remote control synced and light on
TV in standby and won't turn on
Unplugged this morning and left it
plugged it all back in some hours later
pressed the button under puck for 20 seconds
reset remote
pressed 4 and 5
then 1 and 3
lights are all on
but TV won't come on !!!
Locked
This message was authored by: Greenfingers001
Re: Puck TV won’t turn on
Hi there, I will escalate this to our community chat for you. Please look out for an email or chat bubble. We look forward to speaking to you 🙂
This message was authored by: L3g3nd
@PHILLC01
Try a long push on the on button to get tv out of standby and same to turn tv off,and short push to bring puck out of standby and turn on,that's how my puck works on my Sony tv,took a bit of getting used to!!!
This message was authored by: fizzdisco
@PHILLC01
Why not just use the TV remote control to bring the TV out of standby? Select the appropriate HDMI input that the puck is connected to and check that your puck remote is paired correctly to the TV and that you have HDMI control turned on.
This message was authored by: bayardm
@PHILLC01
Has your puck remote previously switched the tv on? If not, you may have to set up the remote using a different channel, I think there’s 15 options, to encompass all functions.
Sky Glass 43” stand mount, Wi-fi, 1 puck, ethernet from Bt disc.
Sky Ultimate and whole home, Diamond VIP User
BT Hybrid FTTC, BT Smart Hub 2 + 1 disc
This message was authored by: Dazzar51
I found pressing the pucks home button turned it all on better than the power button
Sky Glass 55 Gen 1 and x3 Pucks Download 900 upload 900
Avatar for PHILLC01
@Dazzar51 finally TV came on using old Sky Q mini box remote. TV light and puck come on with new remote but screen only turns on with sky q remote
@PHILLC01 Sky Glass remotes have to be programmed to produce the right infra red control code to switch on TVs and control the volume. It is the same process as on Q remotes see the instructions here https://www.sky.com/help/articles/your-sky-glass-remote
Locked
