Discussion topic: Picture settings
Message posted on 24 Nov 2021 04:13 PM
Picture settings
I’m very happy with the picture on my Glass tv until I try to watch something on other apps, egDisney+, when the picture is dull, wide contrast, even in a darkened room. I don’t want to spend time altering picture settings every time I change source. Does any one have easy solutions?
Sky Ultimate and whole home, Diamond VIP User
BT FFTP BT Smart Hub 2 + 1 disc
Message posted on 24 Nov 2021 04:42 PM
Re: Picture settings
@bayardm i find if I set the picture as I want in the custom mode then the picture on the apps look fine as well.
Message posted on 24 Nov 2021 08:13 PM
I have raised the issue with sky regarding the grey look feel to Disney+ channel.
All my other channels are great but Disney+ is shocking tbh.
Been with Sky 23 years and love tech.
Check out my Sky Glass videos to date.
https://youtube.com/playlist?list=PLmDpCnlZ47kNmWGyS6UpR2U9FbTI-sa7S
Message posted on 24 Nov 2021 08:44 PM
@Chrisee That’s the problem, I’ve set my picture using custom settings but they’re no good on Disney.
Message posted on 24 Nov 2021 09:13 PM
@bayardm most Disney content is in HDR if you have set your SDR settings with too high a setting for the backlight much above 50 when you switch to HDR mode the picture will look dull.
Message posted on 24 Nov 2021 09:23 PM
@bayardm Sky Glass doesn't handle HDR very well. Disney plus on Sky Glass doesn't offer Dolby Vision, therefore if set on HDR, everything will appear dull. Unfortunately just down to the limitation of the set
Message posted on 04 Dec 2021 04:22 PM
I agree, shocking picture on Disney + (The Mandalorian) Had to drop the settings in the Disney app down to HD and crank up the colour saturation on the Glass Tv to get a remotely watchable picture. Obviously not fixed in the latest software update unfortunately.
Message posted on 04 Dec 2021 06:36 PM
I've got a Amazon Fire 4k Max plugged into my Glass TV and the picture, be it HD, UHD or Dolby Vision, is excellent.
The internal Disney app not so good.
