This discussion topic is read only Discussion topic: Peacock Battlestar
This message was authored by: jas2000
Peacock Battlestar
Any ideas when Battlestar Galactica will join Peacock content on sky.
The Sky Peackock promo says Battlestar Galactica coming December.
Getting close to Jan now and still no sign.
Thanks.
Locked
Re: Peacock Battlestar
@jas2000  As we are all customers here like you we have no knowledge of when shows or series will be added to Peacock.   Have you tried a voice search?
This message was authored by: LGUser
Thanks.
Battlestar Galactica is available to download as it's available from BBC. You do not have to wait for it to arrive on Peacock.
This message was authored by: Skull+Treaty
@jas2000
Use the iPlayer my friend, don't bother with downloading from Sky.
Avatar for jas2000
Level 4 icon
Lovely job @Skull+Treaty
Never looked on there. Cheers..
This message was authored by: Timelord2018
Bates Motel was added recently and that's still on BBC iPlayer aswell.
Battlestar Galactica is now on Peacock - you need to search for it doesn't yet appear in the Peacock tab
There are some issues with Battlestar Galactica.
From BBC, BG is in SD. On Peacock, it's HD. The two episode mini series is not on Peacock but is on BBC. Also, there are two movies frm 2003 and 2007 that are not on BBC but are on Peacock.
So if you have HD, watch the mini series in SD from BBC and the rest in HD from Peacock. If you only have SD, then watch it the mini series from BBC and then the rest from whichever except for the two movies have to be watched from Peacock.
I noticed that
This message was authored by: ftballman
There's something screwy with at least the listings for season 4 on peacock. No episode 1 or 2 then 2 X ep5 and 6.
The solution is to go to BBC iPlayer and see the order of the season 4   If any are missing from Peacock, watch from iPlayer. Some of Season 4 are also out of order. So you'll have to downlosd out of order. I know this is not an optimnal solution, but it will work.
You can also email Viewer Relations at [email protected] and see what they have to say about the problem.
Locked
