16
This discussion topic is read only This discussion topic has been answered Discussion topic: Not receiving calls after switching to sky
This message was authored by: Avanikamalapurkar
I got iPhone se . Switched my old phone number from o2 to sky . Switch took place this morning . I am able to call and text from my phone with switched number . But I am not able to receive any call or text from other people . When they try to call my number it's saying number you calling is not recognise.
i have tried everything mention in sky help, sky forum . Change settings on my iPhone . Switched off and started again .
can any one please help as I am getting important call tomorrow for job .
cant call sky
Avatar for Avanikamalapurkar
This message was authored by: Avanikamalapurkar Answer
Re: Not receiving calls after switching to sky
@Merida123 @Hi it was Friday 15th may .
Locked
Sometimes when a moved from one network to another takes place as has done this morning the phone itself is displaying the wrong number (the one that came with the sky sim and not your one from O2), to see if this is the case go to Settings - Phone - My Number and if it is wrong try changing it and then reboot the phone.
Thanks for your replay . I have changed my number in settings and reboot still can't receive any calls or text . On face time and iMessage it's still showing sky number with loading sign can't change that . Hopefully I can get it sorted till morning
This message was authored by: Merida123
@Avanikamalapurkar
When did you place the order to port the number across?
This message was authored by: Murad+MiltonKeyne
Hi. I am facing the exact problem. it is very disturbing. did you manage to fix it? please advise.
Kind Regards,
Murad
This message was authored by: JimsW
I have switched from O2 to Sky mobile. I can make calls but not receive them. If I  call my number it goes to O2 voicemail. Which is useless.
Is your phone an iphone @JimsW because if it is have a read of this:
https://helpforum.sky.com/t5/Sky-Mobile/Apple-iPhone-User-Ported-a-Number-to-Sky/m-p/3629014#M72460
No, it's a samsung galaxy a10
I would still check that your phone itsel;f is displaying the correct number within it's setting because if the O2 number is still shown then this might be the cause of your issue.
Hi.
I had faced the exact problem. Called Sky technical team unlimited number of times. They did not manage to sort out the issue. Ended up going back to the previous network provider. Lost time and money.
Hope your experience will be better than mine with Sky.
thanks
Murad
Success I can now receive calls!
This message was authored by: orekav
I am having the exact same problem.
I have migrated from GiffGaff to Sky on Tuesday (2021-06-22) and since then I cannot receive calls.
I can call, receive and send SMS and use my data package but receiving calls 😞
I have called the support team 3 times and the final answer was "New Simcard". I am really disappointed
This message was authored by: MJB1990
Hi,
What did you do to resolve the issue. As I'm having the same issue with my Samsung Phone.
Ta,
This message was authored by: Patri96
Did anyone solve this ? I'm having the same problem this morning after switching from o2 to sky. On a Samsung j6
Locked
