7
This discussion topic is read only This discussion topic has been answered Discussion topic: Not got a viewing card but box is asking for one help
This message was authored by: Help+me+please1
I can't remember having a viewing card since changing sky boxes and suddenly the box wants one 😭
Avatar for Help+me+please1
This message was authored by: Help+me+please1 Answer
Re: Not got a viewing card but box is asking for one help
@Annie+UK More like the husband moving everything to install toy boxes! 😂😂
thanks 😊
Locked
This message was authored by: pjhaahl
@Help+me+please1
The box definitely needs a viewing card. Have you checked the viewing card slot.
@pjhaahl
There isn't one visible in the slot so unless it's all the way in the box it's never had one: I had one in my old box that was visible.
I vaigly remember being told it didn't need one when the engineer fitted it but that was at least 5 yrs ago 🤦‍♀️
A viewing card is required to decrypt the subscription channels, with out a card you'll only be able to watch the freesat channels an not be able to record or download on demand content
So you have no card in the front slot on the righthand side behind the flap? if so go to channel 106 (Sky One) and what happens
@Annie+UK
🤦‍♀️ Didn't even know there was a flap that dropped down assumed it would be in the card slot above!
so in the flap! There is a card where it's always been 😂😂😂
106- insert your viewing card 🤷‍♀️
@Annie+UK
Slight nudge and hey presto it's working 🙄
thanks for the helpful note to self there is a flap! 🤣
@Help+me+please1 wrote:
@Annie+UK
Glad it was a simple fix, maybe a minor earthquake shook the card loose 😈
thanks 😊
Locked
