Discussion topic: No signal
This message was authored by Antdean This message was authored by: Antdean
No signal
I need to book a engineer visit I have done everything on the app and online like it says still not worked
Locked
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: No signal
@Antdean You are talking to fellow customers here. Did you get it sorted? If not try ringing Sky. The best times are just after 7am or mid evening. What issue are you having? Someone on the forum may be able to advise you.
▪️I AM NOT A SKY EMPLOYEE ▪️
This message was authored by Rhonny This message was authored by: Rhonny
Re: No signal
@Antdean
A No Signal message is usually a TV message rather than Sky, where your TV isn't set to the correct source (ie not showing the HDMI input that your box is connected to). Turn the Sky box on and cycle through your inputs until it displays Sky.
Locked
