The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
04 Jun 2021 04:42 PM
Our neighbours scaffolding is interfering with our sky signal and our cable is not long enough to move the dish so we are unable to receive sky TV. What can we do?
04 Jun 2021 05:28 PM - last edited: 04 Jun 2021 05:28 PM
Not a lot really unless you can pay someone to resite the dish?
04 Jun 2021 09:52 PM
Posted by a Superuser, not a Sky employee. Find out morehi @jan168 you can use the SKY go app.
You can also use your box to access recordings and download material but unfortunately likely to be only for a limited period of time as SKY Q (I can't remember if SKY HD works the same) requries a periodic signal via Satellite to keep active
04 Jun 2021 11:08 PM - last edited: 04 Jun 2021 11:10 PM
Posted by a Superuser, not a Sky employee. Find out moreI think you need to discuss this with your neighbour as they are the ones causing issues
06 Jun 2021 08:34 AM
Thanks guys. Managed to sort with neighbours & in the meantime reset the router and tuned channels using antenna. Should get the dish moved on Monday 😁
