This discussion topic is read only Discussion topic: No Satellite signal
This message was authored by: Amber1986
No Satellite signal
Ive tonight experienced an issue with no satellite signal. I cannot get amy channels and its been fine all day. What a time for it to go on xmas eve!!!
I've tried all online fixes, checked for blockages in front of sky dish, turned box off and back on again and chexked all cables!!! Still no luck. Also sky are on holiday so i cannot speak with anyone.
Hopefully someone can help me.
Locked
Re: No Satellite signal
Unscrew the cables, swap them over and screw them back in (Hand tight)
Also
What are the Signal Strength/Qualities in the Sky Box settings?
See question Q11 in my Sky+ FAQ
Avatar for Amber1986
Hi,
Just so you know i have sky Q
Swapped cables around and still no difference.
Satellite signal strength is 0
Signal quality is 0
Ive never had any problems like this and then all of a sudden it just came up
I'll move this thread to the correct forum then
Ok no probs, so im guessing you cant help?
@Amber1986  You would need to call Sky when they are open again to book an engineer.
Locked
