This discussion topic is read only Discussion topic: Network Proximity Error
This message was authored by: Sovereign+Sharon
I have a 1TB Sky Q box and one mini box.  The Sky Q box was connected via  ethernet and the mini was connected using WiFi however a couple of onths ago the mini box stopped connecting via wifi.  I have now connected it via ethernet but the signal drops out, the broadcast freezes and I get network proximity errors mutiple times a day to the extent that the mini box is unwatchable.  Has anyone else had this issue and if so, how do I fix it?  I've had the same set up for years and this problem only started about 2 months ago.
Locked
This message was authored by: BrizzleTim
Re: Network Proximity Error
Have you turned Wi-Fi off on the mini box, it may still be trying to use that than Ethernet.
Avatar for Sovereign+Sharon
@BrizzleTim How do I do that?
@Sovereign+Sharon
1) Press the ‘Home’ button on your remote control.
2) Scroll down to highlight ‘Settings’ but DO NOTpress select.
3) Press ‘001’.
4) Press ‘Select’
Then: Network -
- 2.4Ghz wireless - Off
- 5Ghz wireless - Off
thanks @BrizzleTim I did that yesterday and for a while it seemed quite stable but this afternoon it has started again 😞
@Sovereign+Sharon Has the Wi-Fi  come back on again on the mini box? Did you try a network reset on the mini?
Locked
