This discussion topic is read only Discussion topic: Netgear AX40 FTTP Configuration
This message was authored by: Dalron
Good Morning All,
I have recently purchased the RAX40 - https://www.amazon.co.uk/NETGEAR-Nighthawk-4-Stream-Router-Medium/dp/B01IX2AO48
Has anyone been able to successfully connect this router to Sky FTTP?
Due to limited options in the GUI, I am struggling to find any settings related to DHCPv6-PD
I have used the follow prefix for the DHCP 61 settings
Netgear_mac_address@skydsl|last_6_characters of the mac
I have tried this with IPv6 set to DHCP and Disabled.
Does anyone have any advice on what to try next?
Thanks in advance for any feedback.
@cookiemonsteruk
Locked
Re: Netgear AX40 FTTP Configuration
@Dalron
Should be abc123@skydsl|abc123 for the DHCP Option 61 field. Internet should be set to automatic IP
I am NOT a Sky Employee
Avatar for Dalron
@jamesn123  Thanks, I've tried that too and no luck.
@Dalron
Can you screen grab the netgear wan settings and lan settings screens
Avatar for Dalron
@cookiemonsterukSure, no problem
Internet Setup Page 1.pngInternet Setup Page 2.pngIPv6 Options.pngIPv6 DHCP Settings.pngLAN Settings.pngWAN Settings.png
This message was authored by: MUFFINTAST1C
@Dalron wrote:
Good Morning All,
@cookiemonsteruk
Dump the Netgear and go for an AX Asus router. Specifically rt-ax86u loaded with Merlin firmware you can achieve what you're trying to do since you can input those options easily in the GUI.
If it's proper FTTP, just have it the router connected direct to the ONT if you decide to go down the Asus route.
Locked
