This discussion topic is read only Discussion topic: Multiple Phone Lines into a building using FTTP?
This message was authored by: THX1138
Hello All
There has been a question in the back of my mind for some time regards to the final days of copper lines to premises that is approaching.
Once we all move over to FTTP, how will multiple phone lines into a premises be handled?
For example:
Today, if a premises has 3 separate copper phone lines entering a building, each one has its own separate nte5 master socket.
Go forward to FTTP only. What will happen in the future when only FTTP is available, based on that same building needing 3 separate phone lines?
Will it require:
  1.   3 separate fibre cables running into the building, each with their own separate ONT for each of the 3 fibre cables?
  2.   1 fibre cable with 3 separate ONTs?
  3.   1 fibre cable and 1 ONT
For (B) the question is to whether a fibre cable to a premises can multiplex multiple phone lines over a single fibre cable coming into the building
For (C) the question is to whether a single ONT is designed to facilitate multiple lines into a building. Or maybe there are special ONTs that can do this?
For me personally I will need to retain 3 separate phone lines into my home and am curious to know whether I will end up with a wall full of ONTs inside my living room.
Many thanks in advance
Cheers
Locked
Re: Multiple Phone Lines into a building using FTTP?
@THX1138
Even a 150Mbs FTTP service can host a huge number of simultaneous VOIP connections: any single 'call' is only using a few hundred kbps of data. The slightly trickier bit is that the typical FTTP telephony provided by an ISP themselves only has one 'number' and uses the single phone handset socket on their router.  To have more numbers at an address (there are no 'lines' any more) the subscriber needs to source their own VOIP solution which lives either behind the router or 'in the cloud': this could be entirely virtual, based on dedicated PBX hardware, or on individual IP handsets.  There's certainly no need for multiple ONTs, and although older hardware models do have one or more Voice sockets, these aren't being used by any current telephony deployment and you won't find them on newer versions.
Avatar for THX1138
Level 5 icon
Hi @TimmyBGood  many thanks for your reply.
I must admit that I’m struggling a bit to visualise how this would pan out.
If I take the scenario below:
  • Livingroom must have its own telephone and internet connection for ‘Personal’ use and have its own unique telephone number and separate internet account
  • Bedroom 2 must have its own telephone and internet connection for ‘Business’ use and have its own unique telephone number and separate internet account
  • Alarm system must have its own unique telephone number
How would Sky sell and physically facilitate the scenario above once all the copper lines are gone and everything is done via FTTP?
Currently with Copper to the property it’s easy to do as you would simply have 3 separate accounts with Sky, coming into the property via 3 separate physical lines, with 3 individual phone numbers.
Sorry if I’m being a bit thick…
Avatar for THX1138
Level 5 icon
Sorry @TimmyBGood
To make it a bit more complicated could a single fibre cable be used by 2 different telephone/internet providers at the same time?
If I take the scenario below again:
  • BT FTTP – providing Livingroom telephone and internet connection for ‘Personal’ use and have its own unique telephone number and separate BT account
  • Sky FTTP – providing Bedroom 2 telephone and internet connection for ‘Business’ use and have its own unique telephone number and separate Sky account
  • Sky FTTP – providing Alarm system must have its own unique telephone number
Cheers for your help and patience.
@THX1138
You're overthinking it.  In the next few years all telephony will become just data, like web traffic is now: your ISP is  the provider of a data conduit.  The individual phones don't have an ISP: they are just the endpoint devices for data tagged to arrive at a particular destination which has been associated with a 'phone number': this could be an IP handset (wired or WiFi) or a computer or an app on a smartphone.
It's worth noting that analogue monitored alarm systems no longer function in this brave new world: you should seek advice from your specialist provider about a replacement.
A single FTTP connection only has one ISP (like any other broadband) but 'phone numbers' are intended to be portable between providers.  For multiple numbers at an address you'd be using a call provider, not the ISP.
Avatar for THX1138
Level 5 icon
@TimmyBGood  You are a star !
Finally I get it - sorry for being slow... It will be like Skype calls today, where they can have a phone number.
I do overthink at times.
Cheers mate
This message was authored by: simon194
I think the easiest solution would be to move your telephony to a VoIP provider.
At home I use a Siemens Gigaset N300A with 4 handsets which supports a fixed line and up to 3 VoIP connections. Currently the "fixed line" connects to Sky's VoIP service and I have two separate numbers from Sipgate for my home office and the rest of the house.
Before anyone says "why have Sky Talk and Sipgate", it's because I don't make enough personal calls during the day to warrant paying the extra for more than the Evening and Weekend talk package.
_____________________________________________________
Avatar for THX1138
Level 5 icon
One more checking question, if I may. @simon194 @TimmyBGood
Imagine we are now in the future and all copper lines to the house are gone – only fibre lines.
  • If I already have Sky Ultra FTTP for my personal internet and VoIP
  • My employer then provides me with a BT Full Fibre FTTP for business internet and VoIP only (maybe because they get a good corporate discount through BT)
Would my home then need to have 2 physical fibre cables coming into it? One for Sky FTTP and one for BT FTTP? This could also be the case if I just need two completely independent internet services from different providers.
I appreciate that all of this is still some 3-4 years away for most of us, but boy does time fly, and before we know it…
Cheers All
You would need two separate cores of fibre fused to two pigtails reaching two ONTs feeding two routers (or conceivably a business-grade router with twin WAN ethernet ports).  However,  standard optical drop-cable to an individual property is typically four-core, so there's spare capacity in that already.
Its similar to how ISPs do it for multi tenant office spaces currently. My companies office building has 5 different companies in it, there is one fibre drop wire coming in from outside which is split off into 6 fibre wires that feed each company. We all can purchase up to 1Gbps.
I am NOT a Sky Employee
We're currently in dispute with a leased-line provider over their attempts to charge us a hefty amount for many hundreds of metres of 'new' connection from the local DP, when all Openreach did was fusion-splice a pigtail onto a spare strand in the multi-core optical cable they put in several years ago...
Avatar for THX1138
Level 5 icon
@jamesn123 @TimmyBGood
This is now getting into the detail I was hoping for. Thanks both.
So, the illustration below, should be how it can be in the future for the homeowner wanting more than one Internet Provider.
@THX1138
Alternatively, according to ISPreview, Openreach may have access to an ONT for that purpose.
https://www.ispreview.co.uk/index.php/2021/01/a-look-at-openreachs-future-4-port-ont-for-fttp-broadb...
It's worth noting that the mechanics of actually ordering a second FTTP service at an address are probably not well established, and would be subject to any particular ISP understanding what you are trying to achieve...
Yeah it should end up being one fibre wire with multiport ONTs that authenticate with different providers or accounts with the same provider
Yeah when we ordered our service the provider was talking about all the required work and saying it would go well above the 'free' 4k grant to FTTP build work. Then they realised cable was already coming in and it would just need running to our office. I bet they still claimed the 4k from the government though.
Locked
