11
This discussion topic is read only This discussion topic has been answered Discussion topic: Muffled DD/DD+ sky sports uhd
This message was authored by: Donfor
re boot hasen't helped.
1st time in ages I've had to revert to normal non DD sound.
Avatar for Donfor
Level 9 icon
This message was authored by: Donfor Answer
Re: Muffled DD/DD+ sky sports uhd
Shall re check hdmi connection today.
i take it no other reports of DD/DD+ muffled sound via hdni sky sports football commentary yesterday.
Locked
Avatar for Donfor
Level 9 icon
Interesting full time commentary is fine, though in game commentary was seriously muffled/distorted.
Avatar for Donfor
Level 9 icon
Since switched to optical which allows both DD/DD+ to work flawlessly,
Maybe I need to re check hdmi connection.
Avatar for Donfor
Level 9 icon
This message was authored by: skinner1965
Soundbox does not support DD+ so should be set to DD in Q box settings
BT Ultra Infinity. Apple Time Capsule. Sky Q 2TB watching UHD through a LG OLED55B7 and listening through a soundbox. Multiroom with 2 miniboxes
Forum ban incoming!
Avatar for Donfor
Level 9 icon
DD was one of the settings I used yesterday-only optical had decent commentary sound.
This message was authored by: belle3584
Just had his very issue. Rebooted the sound box and it sorted the issue out. Also ensure the HDMI lead goes in to the arc port on the TV.
Avatar for Donfor
Level 9 icon
@skinner1965
I thought Sioundobx Does Support DD+ as originally reported.
This message was authored by: DVR101
I bought a new soundbox a couple of days ago and found the dialogue very muffled on many of the movies went watching through the HDMI link but they were fine through the optical connection.
I initially fixed it by changing the Digital Audio Output setting in the Sky Q settings from Normal to Dolby Digital.  This worked fine but weirdly, when I tried to watch the following day, dialogue was muffled again but when I changed the setting back from Dolby Digital to Normal again, this fixed it!
Maybe different moves need different settings or maybe the box needs a reset/setting change to get it working properly sometimes.
This message was authored by: Fluffy-Alan
Hi, I have a similar problem. I got mine last week and the initial setup was perfect but then I have been having an intermittent issue where there is no sound when DD is on but there is sound when set to "Normal". Optical from the TV works fine and so does Bluetooth. Interestingly the Sky Q always defaults to DD when powering on each day? I wonder if there is a way to keep the settings rather than having to change it everyday but then I guess there is somthing wrong anyway as to why DD/DD+ works intermittently?
This message was authored by: mike+simmonds
Hi @DVR101
When a movie soundtrack is encoded and compressed in to a Dolby digital or Dolby Digital plus format , the engineer tries to put different sounds into different speakers within either a 5.1 or 7.1 format
I don't have an 8 separate speaker setup but I suspect these are circumstances where a "7 separate speakers plus a sub" Dolby digital plus setup separates the sound in a more meaningful way than the soundbox
The Soundbox has some trickery but the left speakers are only 12 inches away from the right speaker and I think that's why with some soundtracks it simply can't cope with what the sound engineer is trying to achieve
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
This message was authored by: rpcb61
For me this is resolved by taking out the power cable for 30 seconds and then plugging it back in! But clearly Sky need to look at this!
Locked
