Discussion topic: Moved house and Sky Broadband charge went up.
This message was authored by Doug+L This message was authored by: Doug+L
I moved house in June and the charge for Broadband has gone up. Both TV and broadband more expensive first month, which I understand because of billing period changes, but TV back to normal but broadband has stayed high.
Locked
Re: Moved house and Sky Broadband charge went up.
@Doug+L  It's the first 2 bills that can be higher than normal, have you checked from month 3 yet?
This message was authored by TechmanagerMal This message was authored by: TechmanagerMal
Passing on the tips I have learned in over 24 years as a more than satisfied Sky customer.
Doug+L
No this is the second monthly bill after move but as I said TV charge back to normal.
This message was authored by Daniel0210 This message was authored by: Daniel0210
@Doug+L Has a BB discounted deal now finished and you have started paying the full price. You would have been told the duration of this deal when it was set up. If so it's time to ring Sky and negotiate a new deal.
▪️I AM NOT A SKY EMPLOYEE ▪️
FOR SKY+ USERS: From 29th October 2024 you will no longer be able to pair your viewing card to a Sky+/Sky+HD box that the card is not already paired to, so if your Sky box becomes faulty you cannot replace it and you'll need to move to either Sky Q, Sky Glass or Sky Stream to access Sky content
Doug+L
Hi
Thanks for response. Yes all done via the Sky moving house page, which was great btw.
Doug+L
Been with Sky (this time) for well under 12 months so not lapsed contract
This message was authored by SDR This message was authored by: SDR
What about next months bill? If that isn't lower or where you expected it to be then you really need to phone Sky as only they will be able to explain the charges
Stuart R
I am responsible for the content, but not the way it is presented, I have some sight issues
Auto-Correct is my enemy.
Sky Glass - No Puck
Doug+L
Future bill was also higher. I got in touch with Sky and it appears the joining discount had been removed when I moved house it requires a manual intervention to add it on again. Just noticed today I have also had Sky Talk Anytime Extra removed too as I have been charged for a local call. Will need to contact Sky again, they really need to add Chat again and other functionality back onto the on-line services.
Locked
