7
This discussion topic is read only This discussion topic has been answered Discussion topic: Man united tv
This message was authored by: Man+u+Tv
Man united tv
Can i watch man u TV on sky go?
This message was authored by: MightyQuinn Answer
Re: Man united tv
Hi @Man+u+Tv   I believe that MUTV has it's own App for viewing etc., not Sky Go.
Locked
Re: Man united tv
This message was authored by: bob1234
Re: Man united tv
@Man+u+TvThat would be a separate app and Sky Go does not support apps. If it was listed on the programme guide in Sky Go you would be able to watch it subject to the appropriate subscription.
This message was authored by: Rhonny
Re: Man united tv
@Man+u+Tv
Yes you can!!
Re: Man united tv
Hi @Man+u+Tv  As MUTV isn't part of the Sky Go app then you can't watch it when you are away from your Sky Q box I'm afraid as the channel will only be viewable when the app is connected to the box assuming you have the relevant subscription allowing you to streams channels from the box to the app, is taken from the link Here  and posted by @caesarome
Re: Man united tv
@Man+u+Tv
Possibly another instance where Go behaves differently depending on whether the device is 'at home' (ie on the same local data network as the Sky box) or not.  BBC channels, for example, do not appear in Go when away from home, and iPlayer has to be used instead.
Re: Man united tv
@Man+u+Tv
I should have qualified, yes you can watch it on the Sky Go app at home, but you need the MUTV app when out-and-about.
You can sign up to the MUTV app for free as a Sky Q/MUTV subscriber.
https://mutv.manutd.com/skysignup
This message was authored by: Doc5907
Re: Man united tv
High subscriber rate for the MUTV app in Devon, Hampshire and the South East....
Sky Q 1TB UHD
LG TV
Sky Mobile
Locked
